M8-1.25
OZTENT / Clone owners - Where does one put an oztent for transport? They're like 7ft long folded up . . . is it roof rack only? SQ followup - how much noise do you get with it on your rack? Do you reget having to have it up there? How's the ownership experience?
M8-1.25
Funny you bring that up as I’ve thought about this a lot. I’ve pretty much decided that for me, I’d want it on the passenger side. The scenario that keeps coming to mind is pulling off to the side of the road somewhere to maybe stop for awhile, like a scenic overlook or something. Maybe decide to have a snack and enjoy it for awhile. Go to open the awning....drivers side puts it in the traffic lane / road...You just unfurled your 270 awning. You kick yourself again for getting it on the wrong side. Which side should you have gotten? Left (driver US), Right (passenger US)
I removed the spare tire out of the back of the truck for additional space for a Lowe's run expecting the yellow triangle warning light to come up when I got far enough away from the garage. To my surprise it did not. I then thought that it may come on after re-starting the truck for the ride back home, as the spare would not be around to be scanned by the computer. It did not come on then either. When checking the tire pressure screen, the tire removed showed "Checking" while the others read normal with zero dash warning lights. After replacing the spare, everything worked normal as you would expect.
Not really a question, I was just curious what you all thought on the subject. I was under the impression all 5 tires needed to be on the truck for the triangle Warning light to be off. It appears that is not the case. Maybe you all already knew that.
I also use the interior tire carrier mod created by FlightMedic178 but I doubt that plays any role in this.
Not advocating rolling around without a spare, but good to know you don't have to deal with the eye sore if you are running only 4 tires for a brief moment.
Here is the plug (black loom, black plug):Does anyone have a picture of the backside of the AC plug in the DS cargo area? Is the inverter right there behind the panel or somewhere else?
I've had that issue on a 4Runner due to the little spring that pops the door open failing. You can try sticking a credit card it the gap to pry it open while someone else pulls the lever. I can't remember exactly, but I think I got a new spring on eBay for five bucks or so.The fuel door won’t open on my 2015 LX570. The fuel door mechanism has a small plastic rod which is actuated to open/close. On Saturday, I went to pump some gas and pulled the fuel door handle with no luck. So, I ended up taking it to the dealer. Has any one experienced a similar problem before? I searched and found no results.
I was on a parts site when this came up, here is the part # for the spring: Fuel Door Spring - Toyota (77360-35040) List Price:$5.55I've had that issue on a 4Runner due to the little spring that pops the door open failing. You can try sticking a credit card it the gap to pry it open while someone else pulls the lever. I can't remember exactly, but I think I got a new spring on eBay for five bucks or so.
I think the big silver box right behind it may be the inverter:
Is where you pul the lever seated correctly? I had a similar issue, but it was cause I didn't set the cable back correctly after removing the panel so it wasn't actually pulling the cable when I pulled the latch to open the fuel door.The fuel door won’t open on my 2015 LX570. The fuel door mechanism has a small plastic rod which is actuated to open/close. On Saturday, I went to pump some gas and pulled the fuel door handle with no luck. So, I ended up taking it to the dealer. Has any one experienced a similar problem before? I searched and found no results.
Thanks to everyone who replied. My wife told me that she found a spring when she pumped gas last time. She wasn’t sure where it came from and put it away then forgot about it. So this part costs $5 and the labor about $275 (diagnosis and dealer tech hours).Is where you pul the lever seated correctly? I had a similar issue, but it was cause I didn't set the cable back correctly after removing the panel so it wasn't actually pulling the cable when I pulled the latch to open the fuel door.
