I have a 2013 200 Series and thought I could I use use a USB thumb drive to play music. In reading the manual am I only seeing that I can only use a CD as a music source. Or can I use a USB?
I guess no one has encountered this issue .
OK, THIS IS REALLY PISSING ME OFF!!!!!
2015, nav screen setup>maintenance>personal . I can set the date and mileage, but for the life of me, I cant figure out how to put in the text. I know I've done it before but cant figure out how to edit it now.
Thx for talking me off the ledge.
Answered my own question. For the 3 "personal" items in the maintenance reminder screen, you can EDIT the mileage and the date, but NOT the text. To change the text, you have to delete the personal item and then you can specify new text, mileage interval, and date. Unfortunately, the button text will always read, "Personal,"OK, THIS IS REALLY PISSING ME OFF!!!!!
Looking for the rear end cap off of the driver side running board. LC200
Some road debris jumped up and bit me and ripped mine clean off.
I can trade for factory roof rack cross bars!!![]()
Thank you! But, Charlie S is sending me his.If you want them their yours. Message me directly with your info.
Can you elaborate on the diode mod you did or alternator voltage booster? ThanksIf you install the Odyssey or other AGM battery, you should look into an Alternator Voltage Booster, or do what I did and solder a diode in line with the Alternator Sensing lead to fool the alternator into charging at a higher voltage.
Is this fuse under the hood ? I'm just getting the voltage to charge my aux battery through the National Luna system.I’m not @1MAC, but if you are 2008-2015 (pre8 speed 16+ which may be called 2015 in Australia)...you want either this:
5A MK2 Micro Blade/Low Profile (Electronic fuse version) | HKB Electronics
The Alternator Voltage Booster was the first of its type on the market and is the only unit available that was has been purpose built for alternator voltage boosting.www.hkbelect.com
Or this if you want the ability to tweak exact level of effect:
MK4 Adjustable Alternator Voltage Booster | HKB Electronics
I have used both with success and currently use the adjustable.
It’s been 3 years since I did the mod, but I seem to recall spending less than $5 in parts and about 15 minutes soldering the lead together.Can you elaborate on the diode mod you did or alternator voltage booster? Thanks
Either: kill switch, co-pilot eject switch, or powers on the afterburners.Anyone have any idea what this switch could be or how I could figure it out? Have had my 2010 LX for three months and just discovered it. It’s on the driver’s side against the center console
It doesn’t illuminate in either position so it might not do anything.
