- Thread starter
- #181
cross post
You indicated…”. Center arm proved to be challenging.”Are you talking about the steering arm nut removal? If so you will need heat and the good nut removal tool not the cheap auto zone ones. Let me know if you need a picture.
Ok thanks. No problems removing from the mount riveted to frame that you remember?I know I used a sta beard center arm rebuild kit. I cannot remember a specific difficulty in rebuilding it. It was almost a yea ago.
No, I do not remember a problem removing itOk thanks. No problems removing from the mount riveted to frame that you remember?
. Once those areas were repaired I had a great looking Patina outside and the patches for the radio and speakers. I was going to try and blend in Patina in those areas. The more I looked at it I decided not to put the Patina body back on the restored frame. At that point it became a full frame off restoration.You are right on the drum brakes. I have bled system multiple times. I went from 4 pumps for brakes to 3, to 2, still have 1 1/2 but hopefully will eventually clear out.
