Speedi Sleeve Help!!!! (1 Viewer)
Hogan
Three on the Tree
Forest Lake MN
I'm have one heck of a time getting the right speedi sleeve for the rear output shaft on the transfer case (For the brake dealy). I went to SKF web site to get the part numbers for the seal and speedi-sleeve. The seal was right but the speedi-sleeve was way too big again. The part number for the speedi-sleeve is listed 99189. Any help would be great.
http://www.e-webcatalog.com/cr-skf/cataloglook.aspx
SOR stocks 'em
SOR stocks 'em
Thanks if I need to I'll get it from them. I'm just trying to save the $12.00 in shipping, boxing, walking to the ship out area charge.
I'm hoping to get the part # to order it locally and save about $16.00.
from tech trivia:
Transfer Case
81-84 FJ60 w/H42 4-speed - 1.990:1
85-87 FJ60 w/H42 4-speed - 2.276:1
87-90 FJ60 w/A440F Automatic - 2.276:1
NOTE: exceptions have been found in split-case ratios. Bearing - 3-speed transfer/4-speed tranny adapter
Manufacturer: BCA
Part Number: RW114R (cross: rear wheel bearing, Datsun B210, 74-82)
Part Number: 6306-32R-2NSL - $43.15 CDN
Note: this is like the standard 6306 except with a 32mm center
Toyota PN # 33309-60021 ~ ROUND split tcase output flange, studs included
Specter p/n 180-08H ~ 12" speedo cable extention, great for VSS installs
Seal between the tranny/transfer case that allows the 90 wt to fill the tranny when it goes bad - NOK AE24931
Rear output, where the emer brake drum resides:
Seal - NOK AD2651E
73- 3sp Speedi-Sleeve - CR (Chicago Rawhide) 99177
74+ 4sp 4Speedi-Sleeve - CR 99189
Front output flange:
Seal - NOK AH2261J
Speedi-Sleeve - CR 99147
you should be able to source this at NAPA or other parts stores.
looks like you are using the 74+ 4speed your sig line has an earlier model listed.
from tech trivia:
Transfer Case
Manufacturer: BCA
Seal - NOK AD2651E
Seal - NOK AH2261J
Thanks a ton
Part is in and I'm set at least for that part thanks again.
99177 will work for the three speed and four speed one piece case parking brake drum...
That other number, 99189, is too large for a parking brake drum seal surface and will not work.
The chart is a little difficult to read. 99169 is the Speedi-Sleeve for the Output shaft at the front of the transfer case. 99177 is listed as the Speedi-Sleeve for the rear output shaft oil seal.
The 99177 also works on the crankshaft pulley shaft.
I had the same problem,I took the e-brake drum to a local parts store that does machine work and had them mic it after I bought one that was supposed to work,I think I had to get 99169.The numbers at the end of the speedi- sleeve like 99(169) , 99(177) are size of the sleeve 169 and 177 .If that makes sense.
