To answer some questions (sorry, work has been CRAZY!):
We’ve got an 89 FSM to go along with my 1990 FJ62.
When I bought it, she ran and got about 5 mpg’s, so we knew there was something amiss. Shortly after, my wife was driving it, she died, and threw a CEL code for the TPS sensor. We replaced the sensor (that SUCKED!
), cleaned the throttle body, cleaned the starter injector, and cleaned the valve cover.
At this point, the car would crank, start, idle, then choke and die. No codes.
We suspected a vacuum link and replaced all the rubber and the plenum. Problem not solved.
We removed the EGR and did a full de-smog to eliminate any vacuum leak possibilities. Problem not solved, but when it cranked and idled, it was way smoother and the exhaust was cleaner.
We replaced the charcoal canister and fuel filter, problem not solved.
We replaced the O2 sensors with whatever Rock Auto spec’d for the vehicle (1990 FJ62), the old ones were burned up. Problem not solved.
Finally, I replaced the pump (we had the part, so why not). Pump functions great, we hear it turn on when the key is in ACC ON mode. And then…. SHE STARTED RIGHT UP AND RAN!
We drove her around a bit for 2 days. And then the RPM’s would flash drop to 0 and then fire back up while driving. This happened for 2-3 short drives, but she would start right back up. Then…. She died…. And cranks and does not start.
The CEL does NOT come on when the key is in the ACC ON mode.
This led me to check the EFI and COR relays (all test fine; I’ve got a good DMM). I followed the trees in the FSM and it said I either have a ground issue or ECU issue. So I hard-wired to a new ground from the ECU to see if that would solve anything (it didn’t). Then I found an ECU, swapped it, and still nothing changed.
CURRENT ISSUE: Cranks, no start, no CEL when the key is in the ACC ON mode.
Last month I checked to see if she threw any CEL codes, and she did not. I will check again. But I am majorly banging my head against a wall here. ANY ADVICE IS MORE THAN WELCOME! I’ll even promise Rain to anyone here along the Texas gulf coast… I just won’t promise when it’ll come
Thanks in advance!
PS when we bought it, I could change oil and filters and that was it. So it truly has been a wonderful learning experience. But I’m ready to stop learning and start driving!!
