g-man
longest line first. I think it is drivers rear, then passenger rear, then drivers front, passengers front.
I'm revisting the brakes on my 60 as they're having a new but similar issue.
I replaced the front soft lines and now you have to press the brake pedal down 80%+ before it starts to grab. However when it just about hits the bottom it grabs harder than it ever has. Pumping the brakes has no effect on it.
I'm thinking the booster rod needs to be adjusted?
Brake Booster Pushrod Adjustment tool
This tool is used to set the booster push rod position to interface with the master cylinder. Free, just pay shippinglandtankproducts.com
This guy gives away this tool for free, just pay shipping.
Also, go through the entire brake adjustment protocol in the FSM in order, part of which is adjusting the pedal.
Resource tab at the top of the page my man! It'll be in the Chassis & Body manual.I bled the fronts with a Hobo Freight hand vacuum, it worked pretty well. I did see the fizziness you referenced, so that makes me feel better about how I bled them.
Good looks on the tool. I was considering ordering one from City Racer, but was trying to think of a way to do it without buying one.
Got a link for the FSM? I think I have one, but sitting here at work I'm trying to remember if I do or if its still packed away from our move. Btw, we have big news to that end I have to update you with later this week...
Sweet!!! Thanks.Resource tab at the top of the page my man! It'll be in the Chassis & Body manual.
No worries, I totally get that. I've been going to work to relax lately hahaha.I need to respond to your texts too, been a hell of a couple weeks over here.
I have the brake booster gauge tool if you need to borrow it. I can ship it to you on Wednesday. PM me if this would be of help.I bled the fronts with a Hobo Freight hand vacuum, it worked pretty well. I did see the fizziness you referenced, so that makes me feel better about how I bled them.
I ordered one from the link Jim sent me, but thank you for the offer!I have the brake booster gauge tool if you need to borrow it. I can ship it to you on Wednesday. PM me if this would be of help.
I was reading the FSM today, and I think my rear brakes might actually be a little under adjusted. The handle comes up almost all the way before it holds.Also, make sure that your bell cranks for the emergency brakes and the e-brake cable is adjusted properly. If they are not within spec, these can cause the rear brakes to drag.
Cheers, James
Just be aware the bell cranks and cable adjusters do two different things. Make sure you do the bell rank first, then the cable.I ordered one from the link Jim sent me, but thank you for the offer!
Which part is the bell crank?Just be aware the bell cranks and cable adjusters do two different things. Make sure you do the bell rank first, then the cable.
One thing worth mentioning is to check your brake light switch while you are doing the pedal adjustments. Some of us have had issues where the switch has been adjusted too far down and interferes with the brake pedal return, causing the booster and subsequently the master cylinder to not retract fully.I started working down the list of brake adjustments in the FSM.
No. 1 - Pedal Height
My pedal was way to low, so I adjusted that back to where it should be. Brakes feel much better and its not going to the floor anymore to stop.
However it doesn't have enough power to stop completely above 20mph. Onto Adjustment #2
No. 2 - Pedal Freeplay
This is where I expected to have the biggest issue. Sure enough the Pedal travels twice what it should before it engages the master cylinder. The Pedal should have 1/8"-1/4" of freeplay. It currently has 1/2". I have a pushrod adjusting tool on the way (thanks for the link @CruiserTrash ). Once that gets here I'll set the push rod length and see how it does.
I can see the light at the end of the tunnel finally!!
