- Thread starter
- #21
Considerations:
1. My rig has at least four different spring bushings overall. I wish there were, at most, two.
2. Ideally, you would have all the weight on the front end with the high-steer installed before tacking in the perches and the C&T. That way you can check the tie-rod/spring clearance, pinion angle and caster angles. If someone else does the C&T it's a crap shoot.
3. I'd use the stock springs front and rear. It's going to be hard to get the lift springs to match the front springs without making both front and rear higher than it needs to be.
4. Focus on making it as low as you can. I modded my perches and my outboard kit and now that it's all done I can see where it could be almost 1/2" lower and I wish it was.
In my opinion, you (and I) chose the best high-steer arms and tie rod solution.
What power steering with no shackle reversal?
1. Ugh. I want to avoid that if at all possible.
2. I am considering doing the cut and turn myself. I am local to Kurt/Cruiser
Outfitters and he's done enough of these that he's got it down to a science, though.
IIRC stock caster is 0 degrees, but people will put them up to 5 degrees positive caster? I am assuming that is rotating the top of the knuckle 5 degrees to the rear?
3. my thinking with the OME springs was to use the main leaf from the OME spring.
I thnk I will end up using the OME bushings and then drill out the center of the spring mounts out to accept the pins I already have.
4. Keeping it low is part of the plan. Since I am outboarding the springs for the front axle, I am thinking about possibly frenching the mounts into the frame some how.
I keep waffling on the shackle reversal. I have read enough threads from enough guys saying you need to do it, you don't need to do it. Enough back and forth that I am not really certain that it is necessary. It seems to add significanly to the cost of the SOA, though, as the long travel slip joint is 'special' and I would need to find one that uses a low clearance flange for the front output of the SM420.
