OK. I have the axle mounted and the weight on the truck
The truck has about 300lbs of sand in the back, along with my HEAVY box of spare axle shafts, so I figure I have the weight of a fully laden 'Cruiser there. The rear has moved back about 6" or so, and I think my ride height is about 3" higher. I haven't measured though.
I did some reinforcing of the housing. I welded the drain plug shut, and then filled it in. Then I put in some 1/4" plate on the bottom of the pumpkin. Matches the height of the drain plug surround so I don't feel I lost any ground clearance there.
I also used a RuffStuff diff cover, which replaced the studs with some bolts, so if I have to drain the gear lube out, I just pull the 3 bottom bolts. I call the cover the 'dreadnaught'. I know, its ugly, but its beef and functional.
Shackle angle is 55 degrees.
I am at issue with the rear disc brakes and how they are mounted.
Where everything is, the pins that attach the brakes are interfered with by the spring pack (bottom) or the u-bolt (top). So I am going to try turning the brackets around and see if that helps it. Otherwise, I may just weld them on.
