So what kind of tires are you guys running? (6 Viewers)
I want some!
I'm runnin' 35 MTR's and love em in every thing from snow to sand, but you can always go burlier.
I'm currently running the 33x9.5s BFG ATs on a small shackle lift on sagging springs and have no problem clearning them. they run great on the road but I wish I had someting a little beefer and wider off road.
Chris
im running 33x12.5x15 BFG ATs on stock sagging springs and have a little rubbing when off the road or taking turns at high speeds. I love them on and off the trail and the get good mileage before new ones are needed. Have a lift and need to install it and plan on going up to 35x12.5x15 BFGs once the current tires wear and i put on the lift.
1997 FJ80 Alloy with 315-75/16's (aka 35x12.5x16)
Thanks
Took me a long time to find a set of these and when they arrived, they were pretty beat! Oh well, should go well with the other crap i am doing this weekend!
:flipoff2:
i run a stock 60 with no lift. The PO has some 33x9.50s on it and they fit really good. Can i run 33x12.50s?
lunyou
lunyou
33X12.5's are best on 8" or wider rims. Stock are 6". Without a lift, 33X12.50's will rub, unless you only drive on the street. If you want wider, you should go smaller - 31X10.50's work fine on stock rims.
I am planning on buying 35x12.5/15 for my 60. I already have a lift, but my concern is if my stock gearing can handle the extra load?
HZJ60 Guy said:
37x12.5x17 GoodYear MTR's on Trail ready bead locks.
TB
I think you have to use them for it to count:flipoff2:
You will need to regear. The stock gearing can "handle" the extra load, but you won't have the performance you want (except maybe for driving on the freeway!)
well i like the 33 inch tires but not the width(9.6). I don't do much offroading at all it will be more of a DD with the occasional mild logging trail through the woods.
thanks for the advice.
Oh yeah i think when i change tires i will probably buy some 15x8 white spokes from US wheel $35 apiece'
lunyou
