Builds SLOW 71 (1 Viewer)
I’ve been using the Vibrant Performance V-Band Flange assemblies that have the “Male-Female” flange design and have had the best luck with them staying tight and not leaking if you end up going that direction.
That’s the way to go right there☝🏼👍🏼
Here's a picture of when it was new. You can see how the drive shaft flange would hit the pipe. I fixed the leak for now at least until I get it inspected this month. I ordered new gaskets and I'll give those stage 8 bolts a try, pain to reach all them without a lift.
Maybe see if a slight re-route of the passenger side pipe could be made to avoid the flange - possibly aiming a little further forward before dropping down and coming around more forward of the sump than it already is.(?)
Also, the late 55 flanges, which also have the same spline count as the 60’s, are a bit smaller than those that you have there.
I can also kind of visualize your idea of setting the exhaust up differently altogether and running the pipe(s) on the outside of the frame rails before turning back in. At that point it would be much easier and simpler to just go with a dual exhaust that have both pipes ending behind the rear wheels on each side. Would not really be that bad, you even have me mulling on that now🤔🤔🤔
I didn't realize that, something to look into.
Only problem I see is you would have to go under the frame or through it to come back inside. Any thoughts on sleeving a hole through the frame. Would it weaken it much, fishplate it? I don't like the idea of the pipe hanging below the frame.
One thing I want to change is the engine noise out the muffler. I'm partially tried of the engine noise going through the gears, a bigger muffler is in the plans.
If you just went under the frame somewhere in this area, like I think the early 2F exhaust pipes were, shouldn’t need to cut or sleeve the frame. It would be high enough to not come in contact with the spring or the ground.
Then you’d just run the pipe all the way back to where the frame arches for the rear axle, and then go in above the spring the same as the front.
It seems as though the pipe will be hanging relatively low beneath the front tub mount, and that’s where I’d be concerned about hitting rocks or something, or even being visible, which wouldn’t be ideal either.
Got the new collector gaskets in and they do look nice and thick. Torque to 20 ft./lbs., doesn't seem to be much, but they know better than me. I need to get it safety inspected next week then I'll tear into it. New gaskets and the Stage 8 bolts for the fourth time.
