Build SLOW 71
.25
Yeah I’d say 1/8 to 1/16, any more your just burning tire off.
Toe is set with degrees. Total toe by the book is .10 degree. Split that per side and use a little math via Pythagorean theorem, estimation of the length of the jig you built in the picture, comes out to just under 1/8 of an inch. Sounds about right. Too little and it will track weird. Set it and keep an eye on tire wear to see if it is happy.
Say What?? :D Just kidding, thanks for some great input.
It more important to make sure you start with the steering as straight ahead as possible
So, if I have the rear end jacked up with tires off and run a string back to front (rotor to rotor), I should get the front pretty close to straight, correct? If so, I'll try again to see where I'm at. Thanks again!
I played with the tie rod ends today getting them balanced, discovered one was screwed into much and the other not enough (if that makes sense). Fixed that and reset the toe-in to 3/32nds. so I'm calling it good. I'm saving Craig's invite for something big one day, like fixing my transfer case in Silverton. :)
Waiting now for the new Power Tank shock fill kit to recharge the shocks before moving on to the rear axle. I didn't know the nitrogen had to be checked/topped off every year or so on the King shocks. My old system for filling the shocks was on the primitive side. On a good note, with all the new parts, rad., water pump, hydro hoses for the new coolers, etc. I fired it up and NO LEAKS! That's totally not like my luck.
I tried out the new fill kit from Power Tank. My old setup was ok, but I couldn't fill the shocks very accurate or easy, so I pretty much neglected them. With this setup it's so much easier and I can hit the mark (150 psi) every time. Moving down my "must do" list before May hits. We're planning on a camping trip to the Arkansas Ozarks before the Pig Party, so I need to get cracking.
The power tank is also really nice for airing up tires. Some say better than compressors. I'm at the point I need to decide which route I want to go. Both have advantages and both aren't free and need a place to go.
