yeah doc. that kind of work scares me. i am a one banana guy. the HD drag link cant hurt can it?
No, can't hurt. I'm just a cheap-@ss and the pull-and-turn method is free. Do what you feel comfortable doing.
when turning right he might run out of turning ability in the steering box before he actually gets the knuckles all the way right.
as it sits now the steering box isn't centered, it's turned to the right side. So when turning right he might run out of turning ability in the steering box before he actually gets the knuckles all the way right.
woah, best not let the fiance take the truck to providence than! thanks rick!
Did you get your caster measured?
-B-
Finally - yes.
Castor
Left = 2.6*
Right = 3.2*
peepers, i bet you are contacting the tie rod because of the way the axle is turned on it's rear axis. Not a BIG deal, but it is annoying as you say. Landtank's plates are supposed to eliminate this, but they are not exactly bolt on. There is some drilling required.
FWIW, my alignment shop couldn't mount their gear to the wheels so they charged me an extra $38 to rig up the equipment to the outside of the tyre. You and I have exactly the same wheels and tyres. I wonder what's up with that.
-B-
I had slee's plates on when i was unloaded and sitting at J spring height. I rubbed a little also. Once i added weight and brought the front end down a little, i took the plates off and pressed in slee's blue bushings using landtank's template. Love it! No more tie rod contact and it tracks great.
So even after you cut away your control arm tab you were able to remove the slee plates and use Landtank's plates? BTW, guess who helped me with the install?
