Nubbie Question... I am returning my truck back to stock, SUA. Should I drain the diff fluid before welding on new perches?
Gear oil is not flammable if that's what you're worried about.
http://www.melrosechem.com/english/msd_eng/hs4127.pdf
Not saying I would be worried to weld on the outside, BUT all hydrocarbons (i.e. oil, gasoline, etc) will burn. A "flammable liquid" is one that has a flash point less than 100 degrees fahrenheit. The MSDS on the above link says that the flashpoint is 435 degrees fahrenheit. Therefore, it is not classified as a "flammable liquid", but that does not mean that it will not burn.
Less than 1/8"...its a bit on the thin sideThanks for the input, Long story... here is the short version. Truck was someone elses project when I bought it. Just want to go back to stock. I actually have another stock axle but the perches are rusted and won't properly hold a shock mount. Yada yada... BTW, does any know the wall thickness of the axle housing?
Just FYI.
Good luck
just a thought
