- Joined
- Sep 7, 2004
- Threads
- 513
- Messages
- 2,161
- Thread starter
- #21
Shim?
Okay obviously its best to look at what I am talking about so being the way I am (hate to leave things that are questionable), I remove the right spring Assy to get that shim.
It really does not look like a Toyota production item, looks more like a homemade shim. It is slightly tapered with what looks to be a welded piece of flat steel. It may as well been a shim and someone added the small flat steel latter. It was in place for a long time as it was in rusty condition before. If it was sandwiched between the mount and spring with the large end forward, would it tilt the front axle down in the rear making the drive shaft lower??
I checked the threads before and after removal and looks as it would cinch up just fine without the shim. It may be a caster shim from some cheap alignment shop years ago. But I still can't explain the measurement differences as mentioned in my last response. I am now debating on having the spring arced
3/4" more so I should have my 1/2" raise on the right hand side when installed, and taking out the shims and tossing them or replacing with new.
The U bolts look to be the same in the rear, three in front are the same and one is square.
