PO of my 40 put on a set of Downey 4" lift springs but didn't replace any of the bushings, shackles or Ubolts. I just picked up new parts to finish the job, but when I put the shackles on I realized that the Downey springs are only 2.5 inches wide. The shackles are 3+ inches wide, so there is a lot of slop.
How much of a problem is this? Should I try to fill the gap between the shackle and springs with washers or something? Should I scrap the springs and find something wider? Should I not use these shackles?
I'm confused why Downey would make the spring so much narrower than the mount on the frame. Here's a pic, you can see the width difference. The shackle and frame mount are right on. The spring has 1/2" of slop:
