Seals
Good question. Part of it may be the intended usage of the seal or maybe the vendor. I can tell you that the greased ones are a MESS in the bins. :( Some of the crank seals come in bags of 10 and they are slimey...........I see more of the domesticly sourced seals greased as opposed to the Japanese ones.
If I am not mistaken (and I would bet against myself) it has to do with the application for the seal. A seal that will be used for a water passage will most likely be dry. One used to seal out oil or another viscus fluid will be greased. SURVEY SAYS...
Kurt,
Dunno and don't care. I never buy OEM seals. :D
-B-
I have to return a aftermarket t-case input/tranny output seal as it was way to big. So far it hasn't leaked. I will rub Junks head for luck.
kurt
Kurt,
-B-
Oh my, B, if you care, somebody who looks JUST LIKE YOU has been sighted at my parts counter buying OEM seals. The sly SOB even "pretends" to be you and whines if he doesn't get his "Mud" discount.........I'm thinking identity theft :oMaybe you should worry........ ::)
Rick,
I don't know what to say............ :D
Have you been peeking? ::)
I thought you were talking about geased seals
url]
-B-
The Seals I know get wet sometimes, but I wouldn't say their greasy 8)
Me and some buddies playing with 25lb haversacks of C4
