2001LC
- Thread starter
- #121
VVTi (06 to 07) intakes are plastic and do not come apart, no gasket sold for this. 98-05 are two piece: Split Intake Manifold take a look & Gaskets & Seals PollDoes the newer plastic intake plenum come apart or is it all one solid piece? I was debating taking mine apart (even though i had mistakenly bought the gasket that goes between the two pieces) but i was glad i did. Mine had oil and carbon deposits that i was able to fully clean.
What i found worked best for removing that oil/crud and the carbon deposits in the intake: gasoline on a shop towel. Worked a lot better than any cleaner i tried, wont hurt the intake either.
Mine was from leaking valve cover gaskets.
Best price I found for FPR (on fuel rail) is ~$100 plus.thanks. I've been own the cap and line checking. I wasn't going to replace the fpr but for a possible mpg bump and 76$ I will give it a shot and see what happens.
I didn't think about taking the throttle out and reaching under there. I'm going to try that.
Good lucky on that vacuum hose!
OH WELL!
