SAS SAS #9 Official Page 08/04/25- 08/08/25 (27 Viewers)
SAS 9 Color Choices
  • • Sky Blue
    Votes: 10 9.5%
  • • Spring Green
    Votes: 37 35.2%
  • • Capri Blue
    Votes: 16 15.2%
  • • Mustard / Yellow
    Votes: 42 40.0%
  • Total voters
    105
  • Poll closed .
Edited to say, Taken!
There is a spot at KOA that is about to be open if you would like to move to the back loop, first come first served, let me know either here or on a private message and I'll get the ball rolling...
The site info is:
Site 55, which says "back in, 30 amps, water/electric great for small rigs
dates available are 8/3-8/9
Found this earlier in my front panhard bracket. Going to need to fix that before hitting Colorado.
Sadly it's pretty common . How long you been chasing the death wobble? Your is cracked good. The delta kit fits okish inside one sucks .Also a good time to upgrade to a redhead box with a 105 shaft.
The site info is:
I would love to switch to this spot
Disregard, please. I was hoping that this was in the location where 35-38 is. I want to stay where I am.
Literally the day after I’ve put on the delta control arms. I think the extra 1” offset from the L arms put enough stress on the bracket to crack it.
I don't think has anything to do with it JMO The front pan hard bushing have enough flex in them for the 1" offset, plus the crack is from stress from side to side movement.
I have my front axle moved forward 11/8" for the last 5 or 6 years with out issue. I think it's just luck of the draw. these trucks are getting long in the tooth.
On the other hand I ripped a control arm bracket lose on the front axle last year 🤷‍♂️ also a common issue.
@Mike Shull I'll take one of those 4 spots for the Black Bear run if it is still available.
I will be leading Poughkeepsie on Monday but we are already full.
I will lead a group over Black Bear on Tuesday morning, early. I have plenty of room for this run.
I am also running the Holy Cross trail a week after on 8/14 if you are still in CO. DM me if you are interested as this isn’t part of SAS.
Still have room in the Black Bear Pass run on Tuesday? Add me if so, please.
