- Thread starter
- #101
Frame level. Body level. Three paint stick gap between rear wheel pinch welds on both sides. 2”x4” on front clip member. Keeps body frame gaps in check if lift shifts.
Using 1/4” box channel for body mounts. First one made that sits below A pilllar on PS. Placed it approximately on frame with bolt through. Drilled the hole to fit rubber mount to suite 4 crawler kit. I will dial in exact hole position by grinding frame side interface. Frame side height are different because it sits on curved frame part. I left enough material to dial it in.
I down. 12 to go.
I down. 12 to go.
