Builds rocks and rolls
put in the seats
Inside of cab
I need to fab up a removable bar behind the seats to mount the shoulder straps to prevent spinal compression in case of roll over
fire extinguishers mounted
battery box and storage box mounted
When I originally got the STaK they were having business issues of which they have resolved. Anyhow, I recently learned that I need to pull the STaK out and tighten up the clocking ring. opssss
one step forward two steps back
Hopefully I can get the tcase in and out in 5 hours. We shall see
I never learn
Great to see this thing coming together. I have been following along (lurking) with the build since you tore it down and you have done some great work. Looking forward to seeing how it performs.
Looking good.
You guys amaze me at not only the amount of labor and skill you put into these rigs, but the money in parts and tools needed! I'm once again jealous.
Well I had to take out the tcase to tighten up the clocking ring
I seem to take more steps back then forward
The current arrangement allows for access from the top without removing everything
seats out and two tunnel cover panels off
shifter cables
at the start of the project I began up front and worked toward the back.
I initially made the bracket at the axle wrong
The bracket should be parallel and not perpendicular to the axle.
so time rework
