smritte
I'm going to throw this out here because I didn't see it if it was mentioned.
Motor swaps. I have done more than a dozen swaps in either my vehicles or my friends vehicles. The first thing no-one seems to realize is, you now have a Frankenstein. Very few people will touch it if it has a drivability issue. The reason is, if they have an issue diagnosing it, where is the manual?
The vehicle owner will say, the motor is out of a ..... truck but the throttle body is from....truck, the PCM has this guys custom software so my trans from a Camaro will work. My mechanic friend pieced the factory wire loom for me so I still have the OEM loom. We just had to use a custom module so it would talk to my 80. There you go, it should be simple. OH... I used Auto Zone (gutter cheap parts) for some of the coils when my used ones had issues. OH...I almost forgot, this issue pops up randomly so you probably wont experience it. Remember, if you spend 30 hours trying to diagnose it and don't find the issue, I don't have to pay you.
Most of my swaps have been computerized engines and all of them were CA emissions legal. These are things I tell people up front when we discuss swapping engines.
When someone calls me with an issue, the first thing's I ask are, who did the swap, who made the wire loom and who did the custom software. I have found poorly built wire looms, software issues and interference from things that shouldn't have been tied together in the loom. Most of these popped up after more than a year of "no problems driving". None of these were ones I built.
Most techs don't know how to test things properly. They pull a code and throw a part at it. If that doesn't fix it, they throw more at it. Some diagnostics require a lab scope. Find someone who is good with these let alone owns one. In a normal vehicle, there are quite a number of parameters to test on a vehicle. In a swap you just added in a whole bunch more. If the vehicle owner has "fixed" something with an inferior part, add that into the mix.
If you understand diagnostics, lucky at throwing parts at a problem or have someone real good at these things, go for it.
I do know there are several people here who have successful swaps. You also read about the guys doing it and running into issues. I am going to be biased against them mainly because I have seen so many weird ghost issues over the years caused by the things I mentioned. Some of which were done by "professionals".
If you have it done for you, step up and pay a shop who specializes in engine swaps into an 80. I'm not happy with the power my 80 has and keep thinking about an LS with a 6 speed auto. I'm sure I can do it properly for around 20k. Yea, less if I don't rebuild the motor/trans and cheap out on a few other things. Why do that just to have to keep "fixing" worn out parts.
