Builds RevISK’s ‘80 FJ40 - A Girl Named Norman (3 Viewers)
I don’t believe I have seen your 40 dressed up with the soft top….looks great! Safe travels
Thanks Knuck’s,
Here she is a bit more revealing for this morning’s ride into the city…
There is a lot to like about the soft top and a lot to like about a hard top.
Well, got most everything ordered for the trans/t-case refresh. (Thanks @orangefj45 Georg) with the exception of the fluids and tubes of goo. Doing the oil pan gasket and RMS as well for good measure.
About to leave for a round of work trips, 4 states over the next month, with some family stuff interlaced.
Otherwise been pounding the streets taking the kids to school and general errands.View attachment 3978557
Thanks for the ongoing support!
Your 40 is looking great with the soft top!!!!
Georg @ Valley Hybrids & Terrain Tamer
Parts list - fall refresh New
Norman - fall of ‘25 refresh
Dual Seal Rear Extension Housing Kit
** Kit includes 2 new seals#494122 (installed), 2 new OEM speedo O rings, OEM stake nut, 2 updated magnetic fill/drain plugs w/ crush gasket, and E brake backing plate Allen bolts & lock washers, 1 item
Parking Shoe Kit, 1 item
Part #: 46550-60011
Parking Brake Hardware Kit
1 item
Part #: HBK3
90341-18021 - Updated Magnetic Drain/Fill Plug, 2 items
Note: Updated Drain/Fill Plug with Gasket for ALL Axles, Transfer Cases, and Manual Transmissions
Speedo Housing Core Charge
**Please return REBUILDABLE core to Valley Hybrids along with a copy of this invoice. Core credit will only be issued for GOOD housings. Housing CANNOT have any stripped/damaged threads or broken bolts, if it does a core refund will not be issued.
Fee
1980 FJ40 2F Engine + H42
Oil Filter
Part #: YZZD3
Engine Drain Plug Gasket
Oil Pan Gasket, 1 item
Part #: 12151-61010
AISIN CKT-032 OE Matched Clutch Kit
Clutch Pressure Plates Bolts, 6 items
Part #: 90119-08134
Transmission Reseal Kit H42
Transfer Case Rebuild Kit
Part #: TK3
Updated Drain/ Fill Plugs (Trans& T- Case), 4 items
New HNL Slider , 1 item
Transfer Case Linkage Bushing
1 item
PermaTex Copper spray gasket maker
(Oil pan gasket)
AISIN AB1281B Red Form-In-Place Gasket Sealant
Loctite 88442 Red 272 High Temperature/Strength Thread Locker,
10 x quart Valvoline VR1 - 20w-50 engine oil
Redline MT-90 Trans/T-case gear oil
Front shocks - Bilstein B8 5125 Series Shocks 33-185606
Posting the above as a note to my future self and children when they wonder where their college funds went…
Part #: 46550-60011
1 item
Part #: HBK3
Fee
Oil Filter
Part #: YZZD3
Part #: 12151-61010
Part #: 90119-08134
Part #: TK3
1 item
(Oil pan gasket)
I need to compare this to the parts from Georg @orangefj45 - got the transmission and gearbox in sights.
The dual seal housing is not ringing a bell.
I think you missed beer for that list
Figured that would be a given…
