Replacing radiator as preventative maintenance?
owasso,ok
2004 with 180k miles. Original radiator is very brown on top. Was considering replacing it as planned maintenance. I make a few trips to Colorado per year and wouldn’t want a trip ruined. It doesn’t leak, fluids look good, maintenance has always been kept up, etc. What’s the consensus? Replace it now or don’t worry about it? Also wanted to confirm the part number is indeed 16400-50290. Seems i someone saying the dealers carried a cheaper version- I don’t want that.
OEM can go 15 years without any issues. If denso or koyo radiator is installed.. 10 years.. any chepo radiator.. possibly 5 to 7 years. I installed a cheap radiator into my corolla (city driver) and after 5 years.. notice a smoke coming out of the engine.. pulled to the side and the upper gasket between the core and plastic tank was leaking.
Also inspect for any cracks in the plastic fan. if cracked replace with AISIN or OEM blade. I was lucky I was able to witness a piece of plastic flying off the blade and hitting radiator while I had the hood up!
Mine is 20 years old
Absolutely, Just do it.
I am not taking any chances. I was so close to blow the HG in my 97 4runner over Sierra Nevada mountains back in a summer of 2010! Radiator was OEM (13 years old) but contaminants have clogged the core pretty badly. Once the cap was open the core looked new! but the clogged core pipes were further out of the radiator cap and cannot be seen just by looking down from the radiator cap opening. About 60% were clogged. I caught the temp needle was rising... glad I caught it before it reached red zone.
I use the 16400-50360. It is the same, just cost less. It, like the other 2 (US, Canada and Mexican spec.), of which we can only get 2 (US & MX) in North America and the factory install. Are T-Rad's.
If brown and cracking. Then it has NOT always be keep full and or coolant NOT always fresh. In these we can remove upper radiator hose from radiator neck. Then wipe and let plastic gooseneck dry. If plastic gooseneck crumbs, then it would be a good idea to PM.
Also if radiators' fins have not been kept clean. Deepening on how clogged and with what. It would be a good idea to just replace. Since we can't get perfectly clean in-situ.
Often times, if radiator weak, so is cap. We replace the cap, pressure goes up in system to speak, and weak radiators then crack/leak.
If using aftermarket radiator do replace all foam.
I also replace same time: Both hoses, cap, thermostats and tees if their not new or newish.
yes, this is possibly the most important preventative maint. item. I replaced mine @ 160k miles / 25 years - with ah new CSF aluminum, no regrets - cools amazingly well
When you pull the radiator to replace it, backflush the AC condenser coil while you have access. And since you'll be draining the system, it'll be a good time to replace t-stat, tees, and any hoses that don't look good (I replaced them all, ha).
I'll be curious to see how dirty the exterior fins are on the old radiator when you pull it out.
Tees and stat have been replaced in past few years. Im going to do the upper and lower hoses, cap, new tension clamps with the radiator. Getting it ordered tomorrow
Good idea.
Just as another data point - the reason I have my particular 2005 LX is because the previous owner let the original radiator split open, and then kept driving from what I can tell. That killed the 2UZ in it (at 255K miles) that otherwise probably would have gone for several hundred thousand miles more.
Good idea.
Were they going for the claim of the oldest radiator;)
Summer is right around the corner and your aging less efficient radiator will receive more stress running the AC, hotter outside temperatures during idle and running. Your engine will appreciate efficient coolant performance with the new radiator.
What’s the difference between a 16400-50290 and a 16400-50360. I see both online at my local dealer-the first one is 250 more
I think mine is good too haha.
Jokes aside that's the most low hanging fruit you can pick, just replace it.
