Replacing Exhaust Manifolds with OEM - aka Fix “The Tick”
NorCal
What… A… Job… BUT, man does it feel amazing to have this fixed
I had “the tick” on the drivers side and it was starting to drive me batty, so I decided I had to do something. I researched the DT Headers, and while it appears they are CARB legal now, it wasn’t easy to find them, and I also didn't want to be the first guy to roll up to the Smog check shop and have them freak out. I was also was nervous about the installation given some of the comments in this GREAT thread:
LX470/100 Series Doug Thorley Headers Install Tips, Tricks, Lessons, Parts List, and Tools - https://forum.ih8mud.com/threads/lx470-100-series-doug-thorley-headers-install-tips-tricks-lessons-parts-list-and-tools.1255049/
Given this, I decided to stick with stock. And even if you decide to stick with OEM like I do, still go read that thread. Tons of excellent advice in there. I almost posted in that thread, but wanted to start one for those looking to stick with OEM manifolds given there are some differences with the DT install.
The Rig
2001 LX470 with 250k miles. Sunbelt car (TX & CA) with only small amounts of surface rust. (Yes I know, I’m lucky) But the AHC being in the way makes this tougher.
Cat Pipe:
Started with this, and got nervous right away because two of the studs that connect the manifold to the cat pipe snapped off when removing. (but at least they came off) And then I tried to take off the bolts where the cat pipe connects to the crossover pipe. And those rounded right off. Thankfully I had a rotary tool with a cutoff wheel, and that did the trick and I cut those suckers off.
Motor Mounts
After reading about this job, and seeing I needed to loosen these to raise the engine, I then found this thread (Motor mounts - https://forum.ih8mud.com/threads/motor-mounts.685374/page-8) where many people are reporting good experiences after replacing them. So given that, this seemed like a great “while you are in there” type of job. So I bought new mounts, and when changing out the manifold I just took the old mount completely out. This of course gives you a touch more room. Not sure why no one mentions this, but this does indeed seem like a great time to change these out.
Steering Shaft and Dipstick
I did not take these loose. I could see how it might give you more room, but I think not necessary if you don’t want to deal with it.
Heat Shield
This seems like a simple thing, but was hard to figure out. Once you unbolt it, all you want to do is take it out of the way, but that is easier said than done. Yes you can get it out, but it might take you 30 min to figure out. Or just leave it loose and take it out when you take out the manifold. The same problem happens when you put the new manifold in. I rolled the dice and put in the new manifold at first without the shield. This made the manifold installation much nicer, but then I had to mess around for 30 min to try and figure out how to get the heat shield in.
The Main Event - Manifold Nuts
Man this gets intimidating really quick. The first few top nuts aren’t too bad, but then you are getting into crazy angles with nuts you can barely see. Just do your best to try and make sure the socket is on flush when you get ready to try and loosen. Being a sunbelt car I ended up getting pretty lucky. I was able to get all manifold nuts off without any rounded off/stuck nuts. (Which surprised me given the cat pipe bolts needed cutting off) And of course PB-blast these things even if it is only a few hours before. I forgot to spray one of the nuts, and of course that was the one I tried to do with my impact. The good news is the nut did come off, but it cracked the socket in two places. :O The other nuts that had been sprayed were easier.
Head to Manifold Studs
Even though I bought all new head studs, I didn’t use any of them. After spraying down the old studs and working a nut on and off a few times, they all felt pretty good. I was also nervous about screwing something up when taking out the old studs in such a tight space, so I didn’t even bother. I’m not sure if this was the best choice, but I see in most of the posts this is what everyone else does as well. (For the three studs that connect the manifold to the cat pipe I of course did replace those with new)
Re-install
Strangely enough, this was somewhat easy? I did this the next day and with more patience I was able to find better angles and in this case using an all ⅜” drive setup worked much better to get good angles on the nuts. I was actually able to get all of them from the wheel well. I took a picture of the magic setup. Ratchet, to 6” regular extension to 6” wobble extension, to Universal Impact Joint, to deep wheel 14mm.
Tools
  • There is a good chance you are going to need some brute force method in case you run into tricky rusted exhaust bolts. A cutoff wheel did the trick for me.
  • I personally found that “normal” universal joints were too “wobbly.” I found that “Universal Impact Joints” worked much better for me (Like these: Amazon product ASIN B0CB12QP9Y )
  • I also found out after I did this job that they make “Flex Head Deep Impact Socket” sets. Knowing what I know now I probably would have pulled the trigger on these as they look a little less bulky compared to the ones above.
  • Sometimes I used a 1/2" setup to crack these, and other times I used a 3/8" setup. This will probably depend on the tools you already have, but for some of these a ½ setup with a breaker will probably be needed.
  • To Impact or to not Impact? This seems to be debated on the internet. Some claim it is actually helpful, others claim it just rounds nuts and snaps studs. I tried it on a few, and it did work, but you are always kind of nervous you might just round them off. Still not sure what the right answer is here.
  • As has already been mentioned by many others, make sure you have a variety of extensions. I also purchased some wobble extensions that worked well.
  • And yes, ratcheting wrenches also help!
Parts List
I got all new bolts and gaskets for all the pipes I was planning to touch
Exhaust Tick Parts (for 2001 MY)P/NQtyNotes
Drivers Side Exhaust Manifold17105-50121$241.601
GASKET, EXHAUST MANIFOLD TO HEAD17173-50021$16.361
STUD (FOR EXHAUST MANIFOLD TO CYLINDER HEAD)90126-10015$2.068
Nut for Manifold Stud90179-10070$1.048FSM says torque to 32 ft/lbs
Heat Shield Bolts91621-J0612$0.574
Manifold to cat pipe studs90126-10006$3.653
Manifold to cat pipe nuts90179-10070$1.043FSM says torque to 46 ft/lbs
Manifold to cat pipe Gasket90917-06065$3.551
Drivers cat pipe to crossover pipe Gasket90917-06045$1.281
Drivers cat pipe to crossover pipe bolt91515-61035$0.692
Drivers cat pipe to crossover pipe nut94185-61000$0.752FSM says torque to 30 ft/lbs
Upstream O2 sensor in manifoldDenso 234-4169$45.002
Tools
Star Drive Sockets for the studs - e10 inverted torx$5.001
1/2 Drive 14mm Socket "mid" size. Not deep, but deep enough for stud$8.001
Metric Flex-Head Ratcheting WrenchesPittsburgh Set$30.001
Flex Joints - PITTSBURGH PRO Universal Impact Joint Set$9.001
Lots of 3/8 extensions, including a few wobble extensions.Pittsburgh Set$20.001
Oxygen sensor “tool” or a 23mm flex head ratcheting wrench$8.001
Optional? - Spiral Type Deep Extractor$26.001
Engine/Trans Mounts (for 2001 MY)
Drivers Side Engine Mount1236150121$106.631FSM says torque side bolts to 22 ft/lbs. No spec for top nut
Passenger Side Engine Mount1236150121$106.631FSM says torque side bolts to 22 ft/lbs. No spec for top nut
Trans Mount1237150081$65.601
The culprit:
Old vs new:
All cleaned up ready for new:
The "magic" setup: Ratchet, to 6” regular extension to 6” wobble extension, to Universal Impact Joint, to deep wheel 14mm.
Got Tools?
Oh! I also wanted to talk about the rumors that Toyota “upgraded” these manifolds to reduce cracking. When looking at them side by side there was nothing to indicate anything was different between the two. So I pulled out the calipers and for the flange metal it also measured pretty much exactly the same.
Maybe they changed the way they weld the flange right there?
In any case I was a little bummed by this. Makes me think I might be doing this again in 10 years…
Old
New:
Excellent post, I need to do this too however I am considering pulling the engine and doing the timing belt and both manifolds as well as motor mounts.
This is long past due for my rig. I'll get to it soon enough I suppose...
Lifted the engine at the bellhousing with a piece of 2x4 on the jack pad. Nice and stable and worked well for me. As others have mentioned you need to loosen the fan shroud so you don't crack the fan. I also needed to pop the clamps on the air intake housing.
And yes, when I first got my rig and was starting to add up all the things I wanted to do to baseline the car, I also had the same reaction to just pull the engine. There are a few threads mentioning this, but still seems like it is not super common?
In any case, I've done a huge T-belt service and now this, so I'm feeling better about having done everything with the engine in the truck. But I get it. It would be much easier with the engine out!
I did the driver side 2-3 years ago and the longest job I ever took on the LC. I spent 8 hours, I did not raise the engine. Everything was accessible with the tools the OP mentioned. Here is my view of the OEM exhaust (yes, I used OEM everything from Camelback toyota in AZ). I think even after the installation, I still find a very low ticking sound and it is coming from the driver side. All botls are torqued to spec but had to use extensions to reach few bolts. Not sure this caused a low torque on few of those bolts. I am not very happy with this install as the car care nut channel on YT said the OEM design is faulty from the factory. I think he is right because the flange mount is not welded to the tubes so there is a chance things don't mount properly as it is a about 14 inch long item and all are welded together so getting all 4 holes aligned and getting the metal plate to hold all 4 holes in place and the gasket makes a high chance of leaving some gaps between the gasket-block or gasket-manifold. This is the only part that I will avoid using OEM in the future.
Great write up!
Any noticeable difference in feel with the new motor mounts?
It is funny you ask, I was just about to go post in the motor mounts thread about this. It has actually been pretty great! Surprisingly lower amounts of vibration and just overall makes the truck feel smoother.
I still need to swap CV axles and flanges because I have the clunk, but after changing these mounts, the clunk was somewhat reduced. I think the CVs are still the culprit, but something about the smoother mounts are causing less drive line lash maybe?
I just asked this on another thread, but I’m in the middle of replacing the driver side manifold and need help with the exhaust studs.
When I did this on the passenger side a few years back I ordered studs but none of the studs came out. This time, however 7 of 8 of the studs came out with the nuts. I checked the FSM and surprisingly, it doesn’t have procedures or torque specs for the exhaust studs. Can someone please help me out with this information?
So far my experience with replacing driver side manifold is I thought it was easier than the passenger side (except for the exhaust studs). Maybe that’s just because I had experience with the passenger side or maybe the 2x4 under the engine mount just works really well, but I thought I had better visibility and access to the exhaust manifold nuts this time. I was able to get to the top four nuts and the front two lower nuts from above with the ratchet handle pointing up toward the hood, the rear two lower nuts I was able to get through the wheel well with a long extension.
I removed the heat shield with the exhaust manifold but before that I was able to push it forward out of my way by pushing it into the fan shroud. With the extra space at the motor mount I had no trouble removing the exhaust manifold by pushing it back as far as it would go and then rotating it 90° and pushing it straight down past the exhaust flange.
Honestly, the hardest part of the operation was disconnecting the O2 sensor but once I figured out the clip was on the side of the connector and not the top it was a piece of cake.
