Did this job over the last few days while also replacing a cracked drivers side exhaust manifold. When taking out the driver’s manifold, it helped to fully take out the engine mount so I decided it was a good time to do the mounts as well given the comments in this post.
The rig:
2001 LX470 with 250k miles. Sunbelt car (TX & CA) so not too rusty, but in a dry environment. (Was wondering how dry the rubber was going to be)
Top Bolt:
As others have mentioned this isn’t easy to do. I bought this gear wrench 120 tooth:
Amazon product ASIN B00BTEXQP2 and even with this it wasn’t easy. This is far worse for the LX crowd that still has AHC, as it is RIGHT in the way. You can unbolt the one pipe that is in the way and gently bend it to get a little more swing on a flex head ratchet, but still not easy. I would imagine this is much easier for the LC crowd. I see in this thread there is much discussion about this nut and different methods here. Wish there was an easier way.
Side Bolts:
The bolt with the captive nut isn’t easy to see, but what I found worked best for me was a swivel head ratcheting wrench. Easy to sneak back there and you can guess close enough for the torque. I checked my “torque spec” by seeing how tight it was compared to the non captive nut after I had torqued that with a torque wrench.
Engine Jacking:
Just like others have said I had good luck with doing one side at a time. I also used the bellhousing as the jacking point with a 2x4 on the jack. Just loosen the fan shroud, and also snap off the air filter cover, and you should be good. I had just replaced my heater T’s so I wasn’t too worried about them snapping. I didn’t loosen the front transfer case bolts as others have mentioned and I was still able to get enough clearance for both sides.
Old Mounts:
No ripping like others have seen, but they were indeed hard as a rock. I also noticed the new ones were a little tighter going in than the old ones coming out. So maybe the old ones have compressed a little bit? I should have just put them side by side to take a picture but ran out of time to do that.
Might as well:
You are RIGHT next to the upstream O2 sensors, so I changed these as well with Denso units from
amazon.
The whole time I was doing this I was thinking to myself, how in the world did they do this 20 years ago before these modern tools like 90/120 tooth ratchets and ratchet wrenches existed?!?!?
New one looks slightly taller than the old one?
Old one doesn't look too bad, but hard as a rock:
