Waking up this thread again .. I decided to try and repair the inoperative rear diff locker on my 1995 LC80. I've read through the gold that is the content of this site and it looked reasonably straight forward. Removing the locker went to plan until I tried to tap the locker assembly off of the diff and it wasn't coming loose. That's when I found the 4th bolt of the set of three I thought I had to remove. It's the top left bolt attaching the locker assembly and it's head has been rounded. I'm pretty sure it wasn't rounded by me as it slipped as soon as I tried to move it and I've used a good quality 10 mm socket, ring and open ended spanner to try and shift it.
There isn't enough wiggle room to get a dremel and cutting disk in there or vice grips. I've tried tapping on a 9mm open end but no luck. I looked at maybe filing it off but it would take an age I think, no room for a decent stroke of a file.
Wondering if anyone else has run into this issue and had any success removing or cutting the bolt?
Plan B is to remove the actuator cover but I don't know if I'll end up with a lot of small parts springing out if I do that? Same with he electric motor cover? Has anyone tried to refurb the unit in place?
I've applied 12v to the motor and it draws current and makes a light clicking sound as though it's trying to move.
Appreciate any help.
