remove the intake manifold to clean it? (1 Viewer)
Hammer45
Moffat, Texas
I’m desmogging and replacing hoses and such in route to the rear bumper of the 89 FJ62. Here we are at the intake and testing tps and such and wondering if I need to remove the intake to clean it. I have no idea how to keep crap out of the intakes without removal. Thanks for the feedback.
Hammer45
Moffat, Texas
FYI. That’s where the throttle body attaches. The hole in the background is from the removed but not yet plugged EGR valve.
Vermont
Luckily the 62 has a 2 piece intake design which makes it easier to remove than say an fj60 manifold.
it’s unlikely there is enough carbon buildup down in the runners to cause any performance issues but it won’t hurt anything to clean it. Last aluminum VW diesel intake I cleaned up I used kerosene and brushes for the inside.
Vermont
Oh and be careful if you pull off the intake manifold. Likely before you know it you will have cleaned every square inch of the engine :)
Hammer45
Moffat, Texas
Thanks for the warning..... there is about 1/4 inch of muddy oil all over the engine that calls my name every time I go in the garage.
Spook50
My daughter likes Stitch
Supporting Vendor
Spokane, WA
I pulled mine this winter to remove the air injection rail and while off cleaned it inside and out. To keep it clean I ran the pcv and breather hose through catch cans. It was worth it to me.
I've run one for many years and it's been a great benefit as far as preventing buildup in my intake. I wish I would've taken pictures while I had my throttle body off last summer to show how clean my intake still was/is after more than ten years of running a PCV catch can.
Hammer45
Moffat, Texas
Good tip. I’ve read some threads about these.
dad4x4
Forsyth, GA
Also, my experience before the desmog of my 62 is that it’s a good idea to remove the intake a clean it thoroughly. I had lots of carbon/sludge build up throughout the manifold and definitely affected performance. I have a few pics of this in my 62 thread
Spook50
Supporting Vendor
Spokane, WA
I just bought this one. It’s huge (15 oz) but I’m forgetful. D
I like the idea of the sight hose on that, but given the size of it, having to unscrew a drain plug at the bottom could be messy and not just a little inconvenient to reach given the way our engine compartments are set up.
I've been wanting something similar to this Moroso I found on Summit, which holds 4.5oz and has a bowl you can easily unscrew to drain and wipe out. Not a fan of the $250 price tag on this particular one though.
