ARCHIVE Refreshing your 60 Series Gasoline or DIESEL Alternator Connections Connectors Rubber Boots Ring Terminals Mounting Hardware 33+ Years Later and Why
@Spook50
i produced this related TECH video several years ago , its very hard core technical , and i get into the rubber weather boots too .
enjoy ....
FEN un-sealed ....
FEN Sealed Generation 1...
a 3 wire 2F FEN 55A OEM NipponDenso with all the proper SNOW VERSION cold spec. water PROOF must haves , that i apply for the longest term life cycle of service
the right OEM plated hardware matters too ....
good NEG- ground current flow !
Honestly, that NASA paper on wiring connectors posted by @BurntToast is fantastic…boring read ..but damn good information
Make sure to click ON the audio file via the little speaker’ 🔈 icon …😎
I have a DEESEL male and female connector plugs repair / restore and refresh kit
Includes a OEM rear grey tail boot
These are seen on 12V and 24volts
Genuine NipponDenso Japan Spec.
45A F.E.N.
Externally Regulated
12 / 6 Clocked Tabs
Correct 17mm Pully for Cogged Land Cruiser OEM BANDO Drive Belts …
PLANT A-11 installed in :
- non-cold USA & US Territories like Puerto Rico spec. / Guam / Virgin Islands etc…2F FJ60
- Same FJ40 2F
- this same unit was fitted with a 10 / 6 Clocking Tabs Front Cover and was on many 1/75 - 1990 2F & 3F Carb. / LHD Drivers Side lower mounting locations globally …
@Spike Strip
