Vehicle Purchase | | |
Item | Description | Cost |
Lexus GX470 | 2007, 135k miles | $10,700.00 |
| TOTAL | $10,700.00 |
Maintenance | | |
Fluid changes | 7 oil changes, 3 differential and TD fluid changes, 1 transmission fluid flush, power steering fluid flush, filters and misc washers. | $891.94 |
Engine | PCV valve, 1 downstream O2 sensor, 2 upstream O2 sensors, reman 12-hole, flow-matched fuel injectors, exhaust bolts, springs, flange gaskets | $679.90 |
Undercoating | Woolwax and fluid film | $99.49 |
Tires/alignment | 2 alignments, 2 tire rotate/balances | $180.00 |
Suspension | Front alignment cams, new front LCAs, near rear LCAs and UCAs, new sway bar end links, new sway bar bushings | $589.41 |
| TOTAL | $2,440.74 |
Repairs | | |
Starter replacement | Denso reman starter, crossover pipe gasket, pipe O-rings, replacement heater and radiator hoses, thermostat and gasket, Toyota coolant | $337.72 |
CV axles/rebooting | Two NAPA/Cardone reman axles, warranty replacements on both, All-Pro high-angle CV boots, three sets of wheel bearing seals | $458.97 |
Exterior | Replacement wheelwell splash guards, front inner fender liners, DS tail light | $228.98 |
Engine | New MAF sensor and MAF sensor pigtail | $78.78 |
Steering | Remain steering rack, high-pressure PS hose, PS reservoir | $518.97 |
Brakes | Reman front brake calipers, PowerStop SS brake line kit | $283.24 |
Electrical | Replacement battery | $141.18 |
Interior | Refresh front and rear leather seats, steering wheel, shift knob | $325.00 |
| TOTAL | $2,372.84 |
Upgrades | | |
Wheels and tires | Falken Wildpeak 265R70/17 tires, Vors VE37 wheels, McGard lug nuts, wheel mounting, new 17" steel spare wheel, new Kenda Klever spare tire and mounting | $1,662.20 |
Lighting | LED headlights, tail lights, turn signals, brake lights, ditch lights and switchgear, puddle lights, reverse lights, marker lights | $466.70 |
Armor | ARB skidplates, SRQ Fabrication recovery points, Apex rock sliders | $1,306.49 |
Interior | WeatherTech floor mats, cargo area sound deadening and outlet, switchgear | $424.50 |
Engine | DT LT headers, aFe cold air intake, Borla exhaust, 1/4 wave resonator, SAIS bypass kit, O2 sensor spaces, exhaust manifold bolts and gaskets | $2,395.34 |
Drivetrain | WAT Nomad valve body and lockup kit, Hayden transmission cooler, extended rear differential vent | $2,321.24 |
Towing | OEM Toyota CLass IV hitch, Redarc elite brake controller and harness | $526.17 |
Exterior | Plast-dip emblems, black belt molding, spindle-style grille | $357.19 |
Suspension | Ironman FCP Stage 2 lift kit, DuroBumps F/R bump stops, panhard bar correction kit | $3,065.00 |
Drawers | SHW drawers, finishing materials, sleeping platform, and carpeting | $1,192.25 |
Misc. | Onboard air, MaxiTrac awning, rear door table | $504.00 |
| TOTAL | $14,221.08 |
| GRAND TOTAL | $29,734.66 |
