nice clean work.....
:whoops:
The steel cable and aluminum hawse fairlead is a no-no...
Supposed to use a Roller lead with steel?
Kool, the Viking name on the original picture threw me off...
...Yours is kind of hanging out there in grungeland... thinking about the sands (and MUD!) of time...
I still need to install a main cut-off solenoid under the hood, run the main power cable
Also I am in the process of teaching my 16-year-old daughter how to drive a stick. She has a hard time remembering where the gears are. I think I've found a solution![]()
Snake,
Sorry if this question is answered in the pictures, because I can't see them at work (personal network/storage sites are blocked). Anyway, does the above quote insinuate that you are only running a power cable to the rear and are grounding the winch to the frame? I ask this because I'm about to wire up my rear winch and was thinking about using the frame as a conduit and just running a ground strap from the battery to the frame and from the frame to the winch.
