- Thread starter
- #21
Any tips on putting new pads in, these things are a little tricky! I get top side in and bottom pops out...any help?
Probably need to compress the pistons in further or get them to line up when squeezing them in. Make sure the brake res cap is off or unscrew it enough to relieve pressure.
See if this helps. You wont need to do everything they do. I try to find videos on what i want to do and watch it 100x's...
Looks like I will be going to get a c clamp in the morning, I never in my life...it looks like I need about 1/32 to clear rotors. Hope the c clamp will move piston, nothing else has!!Do you have a c-clamp? It will make your life easier.
EDIT: never mind...![]()
In the past I have used a disc brake caliper spreader to push caliper pistons back in on other vehicles. If you don't have one you can use a 6" C clamp around the back of the caliper and compress it with an old pad. Do not have to disconnect the brake line. Don't forget to clean and lube your brake slide pins.
I pumped brakes, bleed caliper, etc...I haven't seen piston move very much at all. When I had the bleeder open and pushed on piston fluid came out. Grabbing some c clamps in morning!Per FSM: Loosen the bleeder plug, to relieve pressure. Then piston of caliper will move freely. Tips: Attach hose to bleeder so you can direct fluid into catch can, keeping off pads & rotor. Make sure to clean rotor with a degrease to remove all finger prints, oils or grease.
I don't usually find above necessary, but it will work. I generally just get out my channel locks and squeeze the piston in. I also start the job by relieving pressure from booster pump by pumping peddle 40 times with ignition key off.
Half the time I forget to put in the darn little early warning squeal clips, end-up redoing just to get those little guys in.
Break-in pads by drive 30 mph pressing on brake peddle, but do not come to a stop. Do this two or three time at least.
Shouldn't need c camp, but won't hurt. FSM recommend just using a piece of wood like a hammer handle as leverage (before putting pad cage in). As I said, my channel locks are my go to tool for this job.I pumped brakes, bleed caliper, etc...I haven't seen piston move very much at all. When I had the bleeder open and pushed on piston fluid came out. Grabbing some c clamps in morning!
You are talking about the 2 17mm bolts that hold the caliper on,correct?Rears brake caliper bolts 76ft lbf, front brake caliper bolts 90ft lbf
Not sure of size, but yes two bolts that hold the caliper on.You are talking about the 2 17mm bolts that hold the caliper on,correct?
No..not at all...everything is back together. ..time for a test drive. .is it bad that I couldn't sleep last night because I couldn'tget my mind off those stupid brakes or stupid me I should say!! Learned a lot. .thanks for all the info.Not sure of size, but yes two bolts that hold the caliper on.
Edit: Hope I didn't confuse you by listing the front brake caliper also.
