So the coolant lines that run to my rear heater core are leaking. They look just like the lines in this post.
https://forum.ih8mud.com/threads/overflow-bottle-always-low.463511/
The only difference is that the line that's leaking for me is 87209B, not 87209C. This is the line that runs up behind the motor above the transmission.
https://forum.ih8mud.com/attachments/fzj80-rear-heater-pipe-jpg.498489/
I don't want to bypass the heater in the back I want to fix it.
So here's my question. Has anyone attempted leaving the factory lines in place, and running new lines with Silicone heater hose to solve the problem? What diameter silicone heater hose should I use? I know i'll have to make sure the hose does rub and stays away from the cat/exhaust. I'm thinking that it will be more difficult to remove the old and to just bypass and run two new lines.
Any help is much appreciated. I'm looking for ways to bypass the existing lines and run completely new lines. The whole process of removing the originals looks like the toughest part of the job.
