Pathfinder
I am the STIG
My fuel pump is leaking from the Vent hole. The car was just sitting and I started smell fuel and I went out to the garage and found fuel poring out of the hole. I removed the fuel pump and both gaskets and the spacer are there so the pump looks fine. The pump was replaced by the PO about 4000k miles ago. No previous history of fuel leaking in this manner.
I pulled the pump and pressed the pump arm and fuel came out both the out and the vent hole.
What would cause the pump to leak from the vent hole and has anyone else had this happen? Is this just a defect or is there something that would cause the pump to fail?
