Yes, and a get a plastic fan too. Cruiser outfitters would be able to hook you up with new stuff for sure.
I sell those parts. It’s kind of disappointing how readily I am looked to for tech, and how easily I am overlooked as a parts resource.Yes, and a get a plastic fan too. Cruiser outfitters would be able to hook you up with new stuff for sure.
I disagree with this assessment. That metal fan is not penetrating the shroud sufficiently, even as a static observation. As it flexes, it gets worse.Since the fan is locked at all times and intact, replacing the fan currently is only for peace of mind, it will not resolve your issue. Cap is a cheap initial check, but high probability it is NOT your fault. Coolant is at boiling point because it either…
Unfortunately I disagree with this assessment, fan location on the shroud is plenty sufficient. Fan shroud, although very effective, is not necessary and will not impede nor cause overheating. The only time I've experienced true disruption is on 1960s econoline and A-series vans where the radiator sits in the dog box and requires a direct force of air to provide flow. Fan shrouds, on properly functioning cooling systems, aid heavily, but lack-of will not cause overheating if they aren't in place on viscous fans systems, especially direct drive.I disagree with this assessment. That metal fan is not penetrating the shroud sufficiently, even as a static observation. As it flexes, it gets worse.
While it would be interesting as an experiment to add spacers to it until it has enough penetration, I certainly wouldn’t suggest adding more fulcrum to that ticking time bomb.
30 years ago I had a customer come in with his broken water pump that he had bought from me, telling me that I owed him another one, along with a radiator to replace the one that got chewed up when it broke.
When he showed me the flex fan and spacer that were still attached to the mounting flange of the pump, it was a challenge for me not to laugh. But of course, he didn’t know that it wasn’t stock.![]()
Pulled the heater valve out. Waited a few minutes then pulled the fan knob out. Seemed to be after the fan came on the temp rose. Turned the fan off and temp dropped within 5 minutes. My heater valve cable opens the valve just fine. Pushing it in doesn't close the valve. Need to open the hood and close it manually.Just to confirm - not the fan switch, just the heat control lever. FJ40s do not function like a modern car, turning fan on doesn’t actuate the heater valve.
So make sure that you pulled the heater lever all the way out and confirmed the valve opened on firewall in engine bay?
Sounds to me like you've allowed a bubble of air to move.Pulled the heater valve out. Waited a few minutes then pulled the fan knob out. Seemed to be after the fan came on the temp rose. Turned the fan off and temp dropped within 5 minutes. My heater valve cable opens the valve just fine. Pushing it in doesn't close the valve. Need to open the hood and close it manually.
Left you a voicemail earlier today.I sell those parts. It’s kind of disappointing how readily I am looked to for tech, and how easily I am overlooked as a parts resource.![]()
I’m in purgatory today, sanding ceiling plaster. I will be back in the office tomorrow.Left you a voicemail earlier today.
Mark will hook you the $@#& up!I sell those parts. It’s kind of disappointing how readily I am looked to for tech, and how easily I am overlooked as a parts resource.![]()
Thanks. Going to try to grab a new cap today or tomorrow. Not sure on the direct or clutch fan. Took some pictures of what I have. Truck is a 1977, 2F engine.View attachment 3960189View attachment 3960188View attachment 3960190
"noticed the radiator overflow was gurgling and some antifreeze had leaked out."Hot today 90's and humid. Drove the truck home from work, about 25 min on the highway. Got home and heard a bunch of gurgling from the engine. Opened the hood and noticed the radiator overflow was gurgling and some antifreeze had leaked out. Guessing it happened while driving, everything below the tank hose was wet and some even on the side of the battery. There was only a couple of drops on the garage floor so I'm thinking was overflowing while driving. Temp gauge was hovering on the line right to the left of the H. Never went over that line. Not really sure what I should do about it.
Fan blades and airplane wings have a lot in common. Blades and wings cut through air, the resulting higher pressure on one side pushing air (bottom of wing, engine side of fan) causing a difference in pressure, lower pressure on the other side (top of wing, radiator side of fan.)Unfortunately I disagree with this assessment, fan location on the shroud is plenty sufficient. Fan shroud, although very effective, is not necessary and will not impede nor cause overheating. The only time I've experienced true disruption is on 1960s econoline and A-series vans where the radiator sits in the dog box and requires a direct force of air to provide flow. Fan shrouds, on properly functioning cooling systems, aid heavily, but lack-of will not cause overheating if they aren't in place on viscous fans systems, especially direct drive.
Definitely skip the metal/direct fan though, plastic clutch fan is a great upgrade for driving.
When I shut the truck off, then heard the gurgling. Opened the hood. Below the overflow tank the frame was damp, side of the battery was damp and there were a couple of drops of antifreeze on the ground. To be honest, I'm not sure if the overflow tank had anything in it to begin with. Never looked in it before. There is an overflow hose coming from the radiator to the bottom of the overflow tank. Not sure if any antifreeze boiled over and entered the overflow tank as steam and since the tank was/might have been empty, the steam blew through the relief hose?"noticed the radiator overflow was gurgling and some antifreeze had leaked out."
I do not understand this observation. If you have the OEM cylindrical overflow tank, isn't the radiator overflow hose connected to the bottom of the overflow tank? And the relief tube attached to the top of the overflow tank only "leaks" when the overflow tank is full?
"Let it cool down and took the cap off. Coolant is right up to the top. Took the cap off the overflow tank. It's empty. Should I fill it to the Low level or Full level?"
So, the overflow tank that was so full it spit overflow onto the ground, is empty when things cool off? The radiator is full, but the tank is empty? Are you saying the full overflow tank got sucked back into the radiator, and the radiator was full to the neck of the radiator cap?
Is there any chance your overflow tank isn't plumbed properly?![]()
