Hi All,
I'm finally at the point of putting my motor (1978 2F) back together after having cleaned everything from years of oil/mud that frosted everything like a cake nobody wanted. It's all repainted and ready to go back together. I have it on a stand and spun it 180 degrees. I put the oil pan/gasket on with gravity in my favor. However, before moving forward, im curious if there is a preferred order to bolt things back on. I.E., should the head be next, or should I work on the timing cover/gasket, or...
A couple of other things im curious about, with the intent of setting myself up for success, is with the motor in this state, how do I ensure the motor is at top-dead-center I've read a lot about valves and marks... but with the head off I'm not sure? Also, I want to ensure when I put the distributor back in. I put slide it in, again, setting myself up for success, and im not sure how to line it up so the gear seats down in the best position.
Here are some pics of where im at before I put the oil pan/gasket back on.
