- Thread starter
- #121
I thought that may be what that was from. Looks good.
...via IH8MUD app
...via IH8MUD app
Sam, did you check the solenoid yet? Might be just that if you get a click. Lots cheaper than a starter.
Made a mess in my shop fixing my pinion angle issue. Got it dialed to within 2.5 degrees at at the pinion (pinion at 15*, DS at 17* +/-).
A fun mess to make.
@Von Hayek I just happen to have some nice FJ62 wiring diagrams neatly filed in a binder that may help with the wiring work. I am not familiar with the ins and outs of wiring for the vortec engine, but I will warn you that pulling the dash wiring harness is no small feat, if that is required in order to run the stock gauges and other electricals. It involved pulling the ENTIRE dash apart, including unbolting the support frame. I will keep the dash parts from the parts rig incase you break something in the process.
AA has a good pdf of all the parts and modifications required for the swap, if you haven't already looked at it.
I think you'll have to start a build thread in the 60 section on this!
I'm still blowing black boogies out of my nose from cutting the old perches off. I couldn't get the plasma cutter to cooperate and thus, had to go old school with the angle grinder on 1/4 plate.
View attachment 878997 View attachment 878998 So on the drive home the trooper started running like crap, sputtering and puttering under load and the timing missed indicated by the exhaust pulse.
Ran around to advanced auto before they closed to order new wires, rotor, dist cap, and plugs.
Pulled plugs and wires to find this. Somewhat amazed it ran at all. #1,2,4 electrodes are pencil thin and #3 is fused. #2 high tension wire end was broken.
Dist cap contacts have the expected white powder and there was a little oil in there.
I had to rob a wire from the 4runner.
Dig it.
Why do you have to redo yours? Did you f up your pinion angle too.
