Unknown about the retainer, but once i tear in there i will look closer.
Pretty sure i installed the seal to maximum depth to the inner ridge where the 4channels are cut. This truck has abs too.
Not my pic, but similar if not identical parts.
Ryan, are you saying the seal should be pressed flush to the rear or the forward lip?
From what i could find online there is a spec depth for the original design seal, but not the improved seal ending in 6. Im thinking this is just forum folklore though.
Bearings will have to wait though, at least until after this weekend. Ryan, can you pm me a quote to replace bearings and outer seals on rear axles if i pull the axles?
Found a thread on Yotatech.com talking about the dealership "fix" to address the common leak in the 3rd gens.
http://www.yotatech.com/f2/rear-axel-seal-leaking-3rd-gen-4runner-39679/index2.html
mr_schuster , 03-14-2008 09:19 PM
Its been a while since I worked at the dealer, but when I was there we replaced axle seals on almost every Sequoia and 4runner in our area. The inner seal would leak and the rear shoes would become saturated in gear oil. Worst I have seen was a locked up wheel because of the brakes swelling up due to saturated linings. Finally Tech support started helping us out a little by asking us not to install new seals flush against the inner axle housing. We were told the seal itself was not at fault, but the metal ring which resides behind the ABS ring was not properly placed on the axle itself. Engineering flaw. The outer ring on the axle is what the seal rides against. We would apply a light coat of white lithum grease to the axle ring and reinstall the axle into the housing then spin the axle one or two times. Then carefully removing the axle you could see where the seal had been riding on the axle ring, if at all. We would take a measurement with a dial caliper of where the seal was originally and where it needed to be. Removed the old seal and replaced the new one further forward from the old seal by the measurment taken. Sounds like a pain and it was, hopefully they have modified the seal to correct the problem, but if not try to do this if your truck is out of warranty.
