Pre-03 nav delete how-to (3 Viewers)
So my project is complete - successful - but a little more involved. There are a lot of great write ups here so I will try to just add to and not repeat anything. First of all I want to underscore what was written in 360: the Mark Levinson factory amp was unable to respond to my new head unit, and required a significant departure of plan for me, but the outcome was better than I had planned!
Here’s the money shot:
1991580
My parts list included:
Climate controls from a wrecked land cruiser
Sony XAV-X1000 head unit
Rockford Fosgate R14X2 - 4” speakers for the rear doors
Rockford Fosgate R165-S - component speakers for the front doors
Sound Ordnance B-8PTD slim powered sub (this thing is awesome and I’m so glad I got it!)
4” and 6.5” speaker baffles slim-line depth - cheap, although I’m not sure they do much, they were easy to add between the new speakers and the plastic speaker baskets in the doors.
Crutchfield CK10 - amp/sub install kit
EFX 9-wire ultra flex speaker wire 12’
Metra 70-8113
The antenna splitter mentioned earlier, antenna adapter, solder seal connectors (lots of the red ones!), one of those pencil torches and fuel
I ordered 560-DNW1DW10 from Mouser Electronics - tiny bulbs for the climate control - I got 10 because one of them was out, and they ended up having that orange cast so I am glad that I replaced them all - they were $.56 ea, the shipping was pricier.
Here’s some random pics that I thought might be helpful:
1991581
The foam speaker baffle installed behind the speaker. Creates an air tight space? Is that important?
I didn’t notice until later that these four wires, which needed to be switched around following the wiring pin out map, were wrapped together... anyways I went to the hassle of stripping that white and green wrap around the four wires, and basically could’ve left it, so that was 2-3m of time wasted.
There’s some vague language in here about “grabbing the left door speaker” from the Nav DVD drive plug - that’s true! Basically the factory Mark Levinson w/Nav setup sends sound: head unit -> amp -> speakers EXCEPT the front door sound goes from amp -> Nav DVD -> Speaker; so you are looking for two pairs of pink & purple wires by my finger in one of the Nav DVD drive plugs, and you’ve gotta pull those through the bundle to find the 2’ Section that goes amp -> Nav, and the wires that go from Nav -> speakers. This whole thing is assuming you want to use the existing speaker wires in your new setup. As you can see here, I connected the 9wire bundle from my head unit to the existing speaker wires. That worked super well. No reason to run new wires. I used solder seal connectors here after confirming everything was working properly.
This thing is great! I hate how it sits in there, but there isn’t a lot of options unless I move it to the back or I start trimming carpet around. I ran the power through the driver’s firewall, behind the pedals under the carpet, and up under the gear shift trim, then under the carpet there where the awful stain is on the carpet. It’s a little janky of a setup but the wire shouldn’t shift or rub, and isn’t being pinched.
So, that’s the tale of my Nav Delete! Removed the factory amp, new speakers, etc... the sound is amazing, and I love the conversion to manual climate knobs. So much easier. I do not really know what I am doing with this, and I made it work, so anybody can do this.
Also, as previously mentioned, through the classifieds here and eBay I have sold everything but the amp and speakers so far, and I’m basically back to $0. Which is good, because it means my truck is very close to receiving a TJM T17!
Thanks for the report. I like the orange. You will make money on the deal and have a state of the art system. Nicely done
Great job! Looks good!
I think in one of my videos I traded the wires for that front speaker from the nav ecu.
Read everything, watch the videos input up, and ask questions here if all else fails.
Couldn't have done it without all the other input here.
Does anyone know if the center stack parts from a '99 LC will fit an '05 LX?
A very BIG thank you to all the contributors on this post. I have just bought all the parts (minus new head unit as still deciding what to put in). I have a 98 with the Japanese Nav unit and cannot wait to remove it this weekend. I will post pics as I progress. :)
hi..do you want to sell your old nav multi display..im really interesting ..
Uggggghhhh! I'm an idiot. I bought the 3 knob with pigtails thinking I got what I need and I must have totally overlooked the whole rear heat button crap. I thought I read where someone did the "REAR" button to "REAR HI/LO" button mistake like me and held the button down for 30 seconds and it worked. Has anyone successfully made my purchase mistake and made it fully functional, or do I just need to sell and try to source another one? Or is there a way to hack it?
Well, the good news is you have the pigtails, and that's what people tend to have a hard time sourcing. Now you just need the LX digital controller. Sell that unit and keep the pigtails. The LX unit will also match your dash as is.
While I'm here, figured I'd make a list and part numbers that I used to do my nav delete and install a new AA/Carplay unit in a 98-02 LX470. Hopefully it helps someone.
Scosche MDAB 1988-05 GM Micro/Delco Antenna Adapter; Tip only
XCSOURCE SKAA-26 1 Male to 2 Female Auto Antenna Adaptor Cable Aerial Car Stereo Radio Splitter Y Shape MA598
Mount Bracket - Toyota (86211-60071)
Mount Bracket - Toyota (86212-60071)
DKMUS Double Din Radio DVD Stereo Frame for Lexus Lx-470 2002-2008 Toyota Lc-100 1998-2003 Dash Trim Kit Fascia Inner Size 173*98mm Black
ICESPRING 2 Ports Dual USB 3.0 Male to USB 3.0 Female AUX Flush Mount Car Mount Extension Cable for Car Truck Boat Motorcycle Dashboard Panel -(3 Feet)
Seadream 2Pack SuperSpeed USB 3.0 Down Angle Male to Female Extension Cable - Down Angle
AUTO-VOX Cam 6 Rear Reverse Backup Camera License Plate Parking Rearview System of 170-Degree Wide Angle for Cars Truck & RV with Waterproof Night Vision
100 pcs Solder Seal Heat Shrink Butt Connectors Electrical Wire Connector RED
Steinel Reflector Nozzle - for Soldering and Bending Pipes or thawing Frozen Pipes, Nozzle Diameter of 1.30 inches, Formed from high-Grade und Polished Stainless Steel, 07051
Metra 70-8116 Amp Bypass Harness
APPS2Car Parking Brake Bypass Video in Motion Interface Module for Select Pioneer Stereo Radio DVD Receivers - fits All Pioneer AVH AVH-P AVH-X MVH DVH and NEX Video Units
Pioneer AVH-W4400NEX
Metra 72-8104 Speaker Wiring Harnesses
Metra 82-8148 Speaker Mounting Brackets
Rockford Fosgate R165X3
Dude, this is an awesome write up.
What is the Steinel reflector nozzle for though?
Will the pigtails for my LC manual control work with the LX digital controls?
Pigtails should work just fine. The digital and manual have been reported to be completely interchangeable
Anyone know of a place in the US that is shipping the LX double din trim pieces?
I think they installed the '03 airbag, because that was the one that fits the new wheel, but had to re-work the harness... I can't remember exactly, but yes, I do have an airbeg
Any more info on this? I got stuck here.... The airbag from my 2002 has 1 pin connector, the sweet new steering wheel with stereo controls that I wanted to use to do this conversion has the two pins below. The airbags are different sizes, so I can't just slap my 2002 one into the new steering wheel.
Anyone know how to do this conversion?
Hi, it's been a while since I did this mod and I'm ready to sell mine, you're welcome to it just name a fair price and I'll box it up and ship it out.
So, I think this is a two stage bag. It has to go to one of them...
