- Thread starter
- #61
Apparently my understanding of the cruiser wiring is either a bit off or I am just missing something.
How does the driver panel connect in to the window motor of the passenger's window? Is it through the passenger's switch or not?
If it doesn't connect through the passenger's switch then interrupting the brown grounding wire from the control circuit would only stop the passenger's side switch from working.
The drivers switch connects 12V to the passenger window motor through the passenger switch. They are in series. When you push the switch on the drivers door, the +12V to operate the window motor comes from the drivers door, through the drivers door master switch, through the wiring loom, through the passenger door switch and to the motor. The return ground from the window motor goes back through the passenger switch, through the wiring loom, through the drivers switch, then through the window lock switch and finally to the A-pillar ground on the drivers side. When you push the switch on the passenger door, the +12V for the motor comes from the passenger door through the passenger door switch to the motor, and then the ground goes back through the passenger door switch, through the wiring loom to the drivers door switch, through the window lock switch, and then to the A-pillar ground. This is just short of brain damage, and is one of the reasons why we are having so many problems with the windows.
With the relay mod, pushing the switch on the drivers door sends +12V through the drivers door switch, through the wiring loom, through the passenger door switch and to the relay coil (either up or down depending on what you pushed.) The relay activates and connects the window motor to the +12V in the passenger door. The motor is now grounded through the other relay in the passenger door and to a ground point of your choosing at the passenger door. Pushing the passenger door switch puts +12V from the passenger door to the relay coil, and the relay activates, putting +12V to the window motor from the +12V supply in the passenger door. The ground is through the other relay etc. So what the relays accomplish is avoiding all the door switch contacts for +12V power to the motors as well as all the switch contacts for the return ground--not to mention about 20 or so feet of wire. The only voltage and current going through the window switches after the mod is the relay coil current which is very small compared to the window motor draw, and hence the switches should last forever, and not get pitted, etc.
Does this help?
