bump - this should get stickied
Since you're already dealing with the switches I have a quick question I was hoping you could answer. The window lock switch on my '88 is broke off (gone, out since I bought it) in the locked position so all I can do is raise and lower the driver window.
Would it be a fairly easy thing to go in and fix? I don't care if the window lock switch works or not, but I'd prefer it was broken in the position where it allows the windows to be used by passengers
Thanks for any advice!![]()
Think using a few transistors for the Window Locks would work?........../quote]
I could use two diodes per door and accomplish this. One diode for the relay coil switch ground, and a high power diode for the motor ground. Problem is, the return current will still be going through the door switches, which I believe would continue to erode the switch contacts. I'll have to think about using transistors for a bit, but any transistor that passes window motor current would have to be a large power transisitor which are expensive, and require heat dissapation.
EDIT: I think it finally sunk into my head what you are thinking about. I'll have to study the schematic again, but I think that by using a diode in the relay coil ground path back through the master control panel switches, the window lock might continue to function. This could also be done with a transistor circuit, but that would entail running extra wires from each door to the master control panel which would make this easy fix into a fairly difficult fix. After I get some time to play with it I'll post up my results.
No no no, hold on, maybe the post hadn't updated before you read it. Put two transistors in on the brown "signal" wires from the switch to the relay. This then disables the relay, however no through ground and not through power, it just disables the switch. If the driver door switches still worked that would be even better for me.
I am electronicaly impaired and have these issues with my switches,I have the oportunity to a wrecked 80 series and was wondering if I could gut out all the wiring and motors and swap it ,would this work or is it completely a different wiring set up.
If not I will pain stakingly try to follow the path of this thread and maybe just maybe I won't have a electrical fire down th road.
