I have an 04 GX 470 and the front passenger power window drops down an inch after you raise it up to the top . If you raise it again it keeps doing the same thing. Has anyone experienced this? Is the switch bad?
Seems odd, are the window control buttons flashing?
You can reset the button by lowering the window all the way, then, pull up on the switch and hold it until the window hits the top, but keep holding the button up for 2-3 seconds once it is all the way up.
Sounds like the switch logic to control the auto up and down may be confused.
Thanks for this older post by OG GX members!Seems odd, are the window control buttons flashing?
I figured I would ask here rather than making a new thread.
Having a problem with the passenger side rear window control from the drivers switch. The driver's switch can make the rear window go down, but not back up. Tried resetting the switch via 3 second holds on the affected door's switch and I tried disconnecting the battery and resetting / recalibrating all of the switches. I can get the other three windows to work correctly from the driver's switch except the rear passenger.
