nukegoat
Should have bought a Jeep
So theres always anecdotal discussion around atf vs hydraulic fluid vs power steering fluid... and most people fall into one camp or another ideologically but without much discussion on the engineering IMO. In researching this topic myself, i have a theory on why toyota may have suggested atf instead of hydraulic fluid - the viscosity index of atf is more like a multi grade oil rather than a single weight. In short, it is relatively thinner when cold and relatively thicker when hot compared to straight iso32 oil.
In looking at the astm testing method, atf is often in the 170 - 180s for v.i. whereas the beloved dte24 is around 100 v.i. (higher is "better")
Given the wide heat range the pump deals with, it may be reasonable to assume that a multigrade fluid is safer for all temp ranges?
Thoughts?
Thoughts?
