So tonight over a couple of beers I decided to tear into my power Antenna so see why it was not working. The PO had installed a nice CD player, speakers, and new power antenna - but neither the radio or the FJ62 factory power antena switch on the dash operated the antenna.
After a hour under the hood with my test light, and My wife pushing buttons in the cab of the truck...this is what I found out. (she was a very good sport about it and now I owe her a night on the town )
Under the hood there is a factory two prong harness that is comming from the dash up/down switch. When you push the switch up - 12volt comes out of one side of the harness plug, and when you push down, 12 volts comes out of the other side of the harness.
The after market antenna that was installed works a little different. It has a red and a green wire. The red wire is for 12 volt constant directly to the battery, the green is for a 12 volt comming from the radio's antenna lead. So when you turn the radio on - 12 volts goes thru the green wire and the antenna go up, when it's off the antenna goes down using the 12 volts from the red wire.
In more basic terms:
up = needs 12 volts to both green and red
down = needs 12 volts to just red
Now Iam thinking... well that won't work with the factory dash switch, and I found out the radio 12 volt antenna lead is not working either. So I checked with SOR - they want $175 for a replacement FJ62 antenna!!!!
So I broke out a few Bosch relays and wired them up to use the Factory dash switch to operate this aftermarket antenna.
I drew up a little diagram so others can use it.
Now it's back to beer drinking!!
