I have held out on posting about this because I was hoping that somehow my crescent shaped lower control arm was causing somekind of sideways stress on my rear u-joints. No such luck
OK, here are the chain of events that have lead to what sounds like growling u-joints (only on deceleration)
Update:
Edit: everybody likes pictures, so here are before and after pics of my lower control arms:
- Drove 600 miles to Rubithon with no issues whatsoever.
- Upon hitting the pavement, post Rubithon, noticed what sounds like angry u-joints (growling on deceleration)
- Decide I should pull my front driveshaft to see if it helps.
- I'm able to find a sweet spot at about 62 mph with no issues.
- Set my cruise control at 62 and sail smooth for a few hunderd miles.
- Stop for gas a little south of Modesto and realize howl has become exponentially worse on deceleration.
- Decide to pull front shaft in 110 degree temps with A/C water dripping on my head and using Craftsman tools
- Jump back in rig to noticeable improvement but still some growling (drink whole bottle of gatorade in 15 seconds flat).
- Get back into San Diego to discover slip yoke siezed on front shaft and have new front driveshaft built (doesn't eliminate problem).
- Straighten and gusset lower control arms (doesn't fix problem).
- Will pull rear shaft to see if problem goes away but skeptical as rear shaft has almost no angle on it due to adjustable arms.
- If pulling rear shaft has shows no improvement, where should I look next?
- Could I have damaged a bearing? If so, I would assume it to be the output of the transfer or pinion as the front shaft was putting strain on them for ??? miles due to siezed slip yoke.
Update:
- I pulled the rear shaft and the growl upon decelleration became barely noticable.
- However the overall angryness/growl became much worse leading me to believe that the added stress to the front output of the transfer is making the situation worse.
- What should I check or do next? I'm good for a few
but some advice would be most appreciated.
