left.Right or leftView attachment 1815014
Hi folks, You guys have some nice looking LCs here. I've had my LJ78 for a week now. Its on stock 16x6 inch wheels with stock 215/80R16 tires. oh, they look odd and skinny . Without a lift, has anyone gone to 17x8.5, +18mm offset with 286/65R17 tires? Trying to see the biggest wheel/tire I can fit in without breaking anything in the LC. see pix to see what it looks like now. all original...at least so far. thanks for the help!
Nice!!! Based on 255/85R16, you are already at 33x10 inch wheels. Did not realize we could do 33s without lift. the tires look great also.
Really clean looking truck, congrats!
You probably know, but these are great and tough little trucks with the exception of the stock engine. The first generation cylinder heads on these motors are GUARANTEED to crack within the first 100,000km or so (releasing coolant into the combustion chamber). There is a second generation cylinder head which is much much better. There are also a few modifications to be done to help these run cool and prevent future issues. Any idea if the cylinder head has already been upgraded? If it hasn't, then make sure you are prepared for it and budget for it. If you do the work your self, you can fix it for $2500 or so using OEM parts.
There are some great build threads on this forum too. Have a read through them to get familiar with what people do to these trucks.
Builds - 1992 LJ78 build/refresh
Builds - My LJ78 build thread...
Builds - A not so informative LJ78 'build' thread
1993 LJ79 from Malta
There is quite a few threads on the forum with ideas for these trucks now. Search and ye shall find.
Thank you. The truck is all stock, and it is in very good condition. The inside looks like-new. Is there a way to recognize the 1st and 2nd gen heads? I've driven < 300 km since I got it 12 days ago. temp gauge has never gone above the 1/4 mark, and the oil pressure is at around 1/2. I lined the garage floor with plastic. no leaks either. I replaced all the fluids, including the coolant. Thanks again.
----------Unfortunately there is no easy way to tell the difference between the early and later head design. Some say that the factory long block was painted black during assembly, so the original head gasket would be painted black on the edge that sticks out. If the head has been off, the new head gasket would not be painted on the edge. Pretty hard to tell though.
How many kms on the truck? Glad to hear it's running good. If you do some of the preventative work many of us have done, you will greatly lower the risk of problems. They are great vehicles really; I love mine.
The head looks like it was painted black, but there is very little black left. The gasket is shiny silver, so its not painted. At least the gasket looks as if it was replaced, perhaps it the original head. 200km on the truck. The Japanese owner seems to have done a good job with it. See pix below. Thanks for the help!
Do you have a build(s) thread? Awesome cruisersRight or leftView attachment 1815014
I’ve done 2000km so far. Starts up on first turn, and runs well. Does 600 km per tank (about 18-19 gal). Finally got it registered in denver. Had to get a new VIN assigned and emissions done. It’s slow to take off. Is it okay to rev it up to 3500 rpm? It seems my gear changes are at around 3500. 25kmh on the first, 40kmh on the 2nd and 60kmh on the 3rd at 3500 rpm. 4th abd 5th gears are fine. About 110kmh at 3000 rpm. Wonder if it’s too hard for the 2LTE. After weeks of compound abd polishing, it looks a lot better. See new pixI'd say you almost certainly have a new cylinder head on there. Gasket definitely looks new. Also, the original heads don't last 200,000km.
