Plastic body nuts for mounting lights
Mass/NH Border
does anyone have a good part # or source for the plastic nut things that pop into the square on the 60 series bodies? They allow the tail lights and side marker lights as well as lots of the front end parts to be screwed to the body...
I have a few missing and looking to replace them. Happy to buy OEM or aftermarket, but just want to get it right the first try. I think there is just one size used on the 60 but I could be wrong.
Thanks...
link to what i'm talking about below, which might just be the ones I need to grab. Thanks
a true gentleman. I owe you a coffee
FYI, I bought the plastic nuts recommended above and they are too large to fit the holes in the body behind the side marker lights and rear tail light lenses, etc
Anyone else have the right part #. This is is pretty basic level stuff. @OGBeno do you care to share your knowledge?
Thanks in advance
I’m on the hunt as well. In the front there are two different sized square holes for plastic nuts. The smaller ones I do have a part number on - the top center attachment for the grille uses that size. The larger ones for the headlight/corner lens bezel I haven’t found yet.
@Godwin for what it’s worth I have not been able to find the correct one using any of the microfiche scans stuff like on Partsouq. I think I’ve ordered every associated part number and they’ve all been wrong. Most of the time that approach works great, but for whatever reason it hasn’t been the answer here.
If you're not hung up on using Toyota parts, you can head down to your local auto body supply and dig through their racks of plastic nuts and inserts. I've always been able to find something that worked.
Plugs for the corner marker/turn signal lights is 9018905013 and from this diagram
There must have been a parts number change at some point. Both domestic Toyota and Amayama show 90189-05013
90189-05013 is what I ordered and they do not fit the side amber or red marker lights. To be clear these are the 4 single bulb lamps on the SIDES of FRONT L&R and L&R REAR.
I'll go back and double check to see if they fit in any of the tail lamp or front grille and lamp assembly areas. But they DO NOT fit the exterior side marker lamps, which are not pictured in the diagram that was posted. The two pin plug headed to the lamp assembly is shown, bu not the lamp or nut part #
They are 9mm openings. They do in fact fit the tail lamps.
The side markers holes are 6mm by my measurements
OK, these ones might be what I’m looking for. I think I have the correct ones for your 6mm holes. They are square like this but a little smaller and yellow. It’s the same as the plastic nut for top center screw for the grille. Right near the hood latch. Check that out on your truck and see if it also fits the side marker holes.
Hey, is the retaining piece in the pic 90189-04014 the same for the markers on fj62?
Edit for clarification
