I've watched the YouTube video, read a few threads and followed the Slee directions and installed the CDL switch in the dash. I also got into the kick panel and and located the the proper wire for the Pin-7 Mod. That is where I found a hitch ... the black wire with the red stripe (Pin-6) was already cut. I cut the black wire with the blue stripe then and buttoned everything back up. The truck was down for a head gasket repair, so I couldn't test immediately, but now it's running again and I have no CDL at all. It doesn't work with the switch and the light doesn't come on at startup either.
Can one of the wiring gurus point me in the right direction on what may be wrong or how to repair please?
The black box is what I removed the harness from
Here you can see the Pin-6 wire is cut. I have no idea what this wire controls. I do know that my truck's ABS has been disabled by the PO, but do not know how. Based on his other "fixes", if he could do it by cutting a wire he would.
I cut the black wire with the blue stripe. No idea why this isn't working now
