- Joined
- Aug 15, 2005
- Threads
- 776
- Messages
- 5,125
Anyone have a picture of grindng the shift gate off of the tranny for 2 wheel low? I have a 73 FJ40, so can I do this? What years is this trick good for?
Thanks.
Thanks.
I think the possible answer would be that if you had it in low and first gear and romped on it you could fawk something up by sending all the torque to one axle.Colorado Boy-74-FJ40 said:If this is so beneficial, may I ask the question, Why didn't Toyota do it?
Cdaniel said:Steep down hill, hard locker in front, big tires, sharp turn. Steering wheel is reluctant to cooperate in this situation when in 4 low. In 2 low the speed control is there and you can steer it too![]()
Brian, The only way the rear d-shaft won't spin is if the rear wheels are off the ground, or it's removed , and inside the truck!!!!! Earlbsilva132 said:2lo provides less wear and tear on the front drive train as most of the time on the trail you don't need 4lo. Getting out to lock hubs is a pain in the ass, easier to just reach down and shift into 4lo when you need it. Also, this mod will give you an additonal neutral between 2hi and 2lo. This is good if you are flat towing as neither d-shaft will spin while towing. In the N between 4hi and 4lo the front shaft spins.
-Brian
