I've had EFS single-nut adjustable panhards on the 80 from way back. Today to temporarily sort out the punctured rear tyre issue while I get a repair kit I took two of the three Toyota factory 16 x 8 wheels with the 285/75-r16's off my box trailer (I only have three of them) with Chinese full-tread LT AT tyres and swapped them for the two rear wheels on the 80 with quite beaten about Cooper AT-3's. Then I noticed something I hadn't noticed before that the panhard offset seemed wrong.
I measured it (between the inner side of each tyre and the outer face of the applicable chassis rail) and found I get 80 mm on the left side and about 57 on the right side. Very obvious difference when looking underneath. Got me thinking... I currently have 3 inch of lift but used to have 5, and I wonder if I never re-did the panhard offset when I reduced the lift way back then.
What is the *correct* way to measure the panhard offset? The way I did it (with matching rims and tyres each side) seems legit. I'll need to try and check the front panhard now and try to repeat with the steering straight ahead.
It hasn't been causing me any noticable drivability problems, but as the rear doesn't have flares a visual reckoning using the wheel arches at the back gives it away, hence breaking out the tape measure.
I'm going to go out on a limb here and presume that the Toyota factory 16 x 8 steel wheels all have the same offset (claimed to be zero?)?
