P3: Jacob's FZJ79, 1999, LX, Tan (2 Viewers)
Riyadh, Saudi Arabia
TIME FOR A NEW DOCUMENTATION:
  • TOYOTA LAND CRUISER, FZJ79, LHD
  • 1999, GCC, Qatari spec
  • Factory AC and Heater
  • LX spec "RPM, Split rear window"
  • Tan with original paint
  • About 180k km
    "112k miles"
  • Manual five-speed, H150
  • 1FZ-fe engine, Coil Pack
Last year, I attempted to sell this FZJ79 to the USA, but unfortunately, we had no luck. We were able to sell it locally so that we can move on. Then we repurchased it last spring. Then Last summer I tried again to sell it to the USA. Still, I encountered many unserious buyers, with some doubting the process, another was offering 13k for it, and numerous negative responses. Then, in September, a message appeared here from Jacob @vansfromjapan, who seemed to know what he wanted and had done enough research to assure that I am not a scammer seeking American money. Haha. The first text was sent on September 8. We exchanged texts, and Jacob proved to be a good negotiator. Then, ten days after the deal closed.
Hint: I keep telling my fellow Americans, you are buying from an Arab, you can negotiate
The truck arrived at my place, and then I had another text exchange with Jacob to understand what we should do with the 25-year-old truck. A full service was the decision.
Areas to address:
  • Front crank seal replacement: Front seal is not good, but we will check the rear one when we lower the trans
  • Transmission and transfer case: they will be on the ground this week, then a complete cleaning, new seals, and switches.
  • Front differential rebuild: This includes all the bearings and a complete gasket kit for the knuckles
  • Break refreshments: It is an old truck, but rotors and drums need machining only; we are going to replace all parts around them.
  • Cooling system refreshments: For such a truck, I always recommend installing a new radiator unit, but we will also be replacing additional components in the system.
We start unplugging all axles componints to add the new goods
Front axle is good with no bad oil but we are going to replace it anyway.
  • Bearings:
    90368-49084
  • Strearing bearings:
    90366-20003
  • Knuckle kit:
    04434-60051
  • cylinder kit
    04479-60070
  • Seals
    90311-62001, and 90310-35010
  • Break pads
    04465-60340
  • Front main hose
    90947-02B51
  • Break short hoses
    90947-02B48
Stearing components are receiving a good amount of lower arms bushes and end rods by the trusted 555
  • Lower arms bushes
    48061-60050
  • Control rod bushs
    48706-60070
It is the first time I see bad spindle bearings, so we orderd new bearings and the locking bushs
  • Bearing
    90364-33011
  • locking bushs
    90381-35001
Shafts ends are good
The rear drums is receiving the following parts
  • Shoe kit
    04495-60070
  • cylinders
    47550-60120
  • Strut sets
    47061-60030 RH
    47062-60020 LH
  • Springs for Shoe
    90506-18031
  • Inner wires
    47616-35030
  • Rear main hose
    90947-02B52
Alright!
I like my part guy; he allows stocking LC parts. However, sometimes he gets it wrong. This time, the 555 end rods were short and missing the back side. I don't know the'hell of what he gave us, but we are returning it. If no 555s matching what we unscrewed, we will get OEM.
The front diff and calipers are washed and nicely done, but I'm waiting for the rods and the hoses.
I am not happy with the cleaning, but I will find out later how to wash it. I already asked them to clean with gas, but it looks like it needs more.
The beautiful hoses showed up! There is no excuse not to replace a 25-year-old hoe.
I keep remembering @OGBeno 's comment about the fan, which mentioned that it was made of plastic, haha. a new whater pump is comming too.
I figured I would replace the PS's reservoir hose as well.
Then, the nasty transmission is sent to my friend Moboark so he can ensure all components are in good condition and allow us to heat-wash all aluminum bodies, enabling us to install new parts like switches and seals.
Nasty switches.
One of the parts we need to change is the bush for the case's shifter.
